SWIFT Solar Wide Functional Headlamp August 31, 2016 08:00PM |
Re: SWIFT Solar Wide Functional Headlamp September 26, 2016 03:53AM |
Re: SWIFT Solar Wide Functional Headlamp September 26, 2016 12:34PM |
Yes, as you said a surface would have minor cavities and it becomes rough, than silicine o-rings might not stop the moisture due to weak contact. Probably, the solution lies in using special glues (for screws) and silicone grease, they could fill the connecting area. How do you think, will it help?Quote
Andrey_SSh
Printed parts always have cavities. High waterproof is unreachable without additional works.
Re: SWIFT Solar Wide Functional Headlamp September 27, 2016 03:35AM |
Re: SWIFT Solar Wide Functional Headlamp September 27, 2016 04:46AM |
Re: SWIFT Solar Wide Functional Headlamp September 27, 2016 09:32AM |
What if to print with almost 100% filling? I read somewhere, that PET has very strong adhesion between layers, so layer bonding is superb. Assuming that a case thickness will be about 5mm.Quote
Andrey_SSh
"Connecting area" is not the whole problem. Soakage trough tiny cavities inside solid walls will take place. Heavy rain drops will produce high dynamic pressure during impact and small amount of water will soak inside.
Seems not bad, I thought about that but it could spoil the thread. Thanks, I'll take this method into accountQuote
NoobMan
Maybe you can try the "acetone vapour" finishing of the prints. It might help with the insulation of the printed parts. At least it seems like this.
Re: SWIFT Solar Wide Functional Headlamp September 27, 2016 08:27PM |
Re: SWIFT Solar Wide Functional Headlamp October 20, 2016 03:57PM |
