I salvaged a stepper motor from a hp laserjet 1020 printer that had broken. The motor specifications are on the second page of the pdf listed below or further down for a cut/paste of the info.
www.mitsumi.co.jp]
My question is can I use this stepper, in combination with say 4 nema 17's or 4 other mix and match printer motors from other broken printers, to drive my prusa.
I've done the vitamins and plastics stage of my prusa and am moving onto the electronics phase. I have a great local support group for the the build but I thought I'd post in this section with my questions first for this specific issue before I bug them.
Motor Specs
Item 49SP-2K
Rated Voltage DC 24V
Working Voltage DC 21.6~26.4V
Rated Current/Phase 1A(PEAK)
No. of Phase 2 Phase
Coil DC Resistance 4.6O/phase±7%
Step Angle 7.5./step
Excitation Method 2-2 Phase excitation (Bipolar driving)
Insulation Class Class E insulation
Holding Torque 134mN•m
Pull-out Torque 100mN•m/1,100pps
Pull-in Torque 102mN•m/250pps
Max. Pull-out Pulse Rate 2,150pps
Max. Pull-in Pulse Rate 430pps
Thanks in advance.
-Bobby
Edited 1 time(s). Last edit at 01/10/2012 04:45AM by bobby_rep.
