Hi here is the specs of the stepper motor. can you please inform me about if it works with sanguinolulu. I have tested the motor with board but stepper drivers are getting too hot. I am afraid of destroying drivers.
Thanks
MOTORES PASO A PASO
MARCA MINEBEA Co. Ltd - ASTROSYN
STEPPING MOTOR
TYPE 23LM-C355-P6V
BIPOLAR
RATED CURRENT/WDG 1,5 Amps
WINDING RESISTANCE 2,2 Ohms
HOLDING TORQUE Nm (Kg-Cm) 0,614 (6,2)
INDUCTANCE 5,5 mH
ROTOR INERTIA 0,110 Kg-Cm2
DETENT TORQUE Nm (g-Cm) 0,0540 (550)
WEIGHT 450 grs.
2.1 V
COIL 1.4 Ohms
1.8 Deg/Step
