technical issue on paralleling 4 z-azis stepper motors April 21, 2015 04:07AM |
Re: technical issue on paralleling 4 z-azis stepper motors April 21, 2015 04:22AM |
Re: technical issue on paralleling 4 z-azis stepper motors April 21, 2015 11:29AM |
Re: technical issue on paralleling 4 z-azis stepper motors April 21, 2015 01:45PM |
hamonic
I have 24v input into Mainboard already, but Not 100% sure how the driver work.
first, my board only have one output for z axis,
if using your way, which mean connect all 4 stepper motor in serie, then it will yes keep the current all same, but spread voltage among all motors, am I correct?
Re: technical issue on paralleling 4 z-azis stepper motors April 22, 2015 03:44AM |
Re: technical issue on paralleling 4 z-azis stepper motors April 22, 2015 04:36AM |
Re: technical issue on paralleling 4 z-azis stepper motors April 23, 2015 12:17PM |
Re: technical issue on paralleling 4 z-azis stepper motors April 23, 2015 01:06PM |
hamonic
Thank you for your advice, I think my motors can work from the driver.
it comes my interested to understand the logic and calculation.
let say, my single motor require 2.8V 1.68A.
If I have 12v PSU, the current I need for this motor is proportional to PSU, which is (2.8/12)×1.68A=392mA
and for same logic if using 24V, the calculation is (2.8/24)×1.68A=196ma
Above is correct situation for the driver work?
hamonic
I though the driver would regulate power to the need/requirement of individual motor, even the input power is 12 or 24 or whatever voltage. Which mean if the motor need 2.8V, then the driver would automatically adjust voltage from 12 or 24V down to 2.8V, isn't it correct?
hamonic
Another interesting question is,
for total power from PSU, if I am about making a super large print platform, something like 1meter by 1 meter hotbed, then I may need to have PSU exceed 120W x 25= 3000w (multiply by 25 because one regular hotbed is 200mm by 200mm, 1meter × 1meter is about 5×5=25piece of regular hotbed size)
do you think the mainboard can support that much power?
for people making that big platform, which kind of board can be an option?
Re: technical issue on paralleling 4 z-azis stepper motors April 24, 2015 11:25AM |
hamonic
Re: technical issue on paralleling 4 z-azis stepper motors April 24, 2015 02:21PM |
NoobMan
... The 4 motors in series would make a 6.68ohms coil and the inductance would be 4 times of a single motor, so you probably "really" need 24v to make the Z axis able to move practically, even with a low speed, depending on load too. You could try maybe find a construction solution with a very lightweight Z and only 3 motors, imo that should be better than four.
Re: technical issue on paralleling 4 z-azis stepper motors April 30, 2015 06:42AM |
Re: technical issue on paralleling 4 z-azis stepper motors April 30, 2015 07:12AM |
