TMC2130 Extremely loud April 27, 2019 11:59AM |
14:46:10.580 : X Y Z 14:46:10.581 : Enabled false false false 14:46:10.581 : Set current 1000 1000 1000 14:46:10.583 : RMS current 994 994 994 14:46:10.586 : MAX current 1402 1402 1402 14:46:10.587 : Run current 17/31 17/31 17/31 14:46:10.588 : Hold current 8/31 8/31 8/31 14:46:10.590 : CS actual 8/31 8/31 8/31 14:46:10.590 : PWM scale 1 1 1 14:46:10.591 : vsense 0=.325 0=.325 0=.325 14:46:10.593 : stealthChop true true true 14:46:10.593 : msteps 16 16 16 14:46:10.595 : tstep 1048575 1048575 1048575 14:46:10.596 : pwm 14:46:10.596 : threshold 0 0 0 14:46:10.597 : [mm/s] - - - 14:46:10.598 : OT prewarn false false false 14:46:10.599 : OT prewarn has 14:46:10.600 : been triggered false false false 14:46:10.600 : off time 5 5 5 14:46:10.602 : blank time 24 24 24 14:46:10.602 : hysteresis 14:46:10.603 : -end 2 2 2 14:46:10.603 : -start 3 3 3 14:46:10.605 : Stallguard thrs 0 0 0 14:46:10.605 : DRVSTATUS X Y Z 14:46:10.606 : stallguard 14:46:10.606 : sg_result 0 0 0 14:46:10.608 : fsactive 14:46:10.608 : stst X X X 14:46:10.608 : olb 14:46:10.609 : ola 14:46:10.609 : s2gb 14:46:10.609 : s2ga 14:46:10.611 : otpw 14:46:10.611 : ot 14:46:10.612 : Driver registers: X = 0x80:08:00:00 14:46:10.612 : Y = 0x80:08:00:00 14:46:10.614 : Z = 0x80:08:00:00
#define X_DRIVER_TYPE TMC2130 #define Y_DRIVER_TYPE TMC2130 #define Z_DRIVER_TYPE TMC2130 #define X2_DRIVER_TYPE A4988 #define Y2_DRIVER_TYPE A4988 #define Z2_DRIVER_TYPE A4988 #define E0_DRIVER_TYPE A4988 #define E1_DRIVER_TYPE A4988 #define E2_DRIVER_TYPE A4988 #define E3_DRIVER_TYPE A4988 #define E4_DRIVER_TYPE A4988TMC2130 config:
#if HAS_TRINAMIC #define R_SENSE 0.11 // R_sense resistor for SilentStepStick2130 #define HOLD_MULTIPLIER 0.5 // Scales down the holding current from run current #define INTERPOLATE true // Interpolate X/Y/Z_MICROSTEPS to 256 #define X_CURRENT 1000 // rms current in mA. Multiply by 1.41 for peak current. #define X_MICROSTEPS 16 // 0..256 #define Y_CURRENT 1000 #define Y_MICROSTEPS 16 #define Z_CURRENT 1000 #define Z_MICROSTEPS 16 #define X2_CURRENT 800 #define X2_MICROSTEPS 16 #define Y2_CURRENT 800 #define Y2_MICROSTEPS 16 #define Z2_CURRENT 800 #define Z2_MICROSTEPS 16 #define E0_CURRENT 800 #define E0_MICROSTEPS 16 #define E1_CURRENT 800 #define E1_MICROSTEPS 16 #define E2_CURRENT 800 #define E2_MICROSTEPS 16 #define E3_CURRENT 800 #define E3_MICROSTEPS 16 #define E4_CURRENT 800 #define E4_MICROSTEPS 16 /** * Use software SPI for TMC2130. * The default SW SPI pins are defined the respective pins files, * but you can override or define them here. */ //#define TMC_USE_SW_SPI //#define TMC_SW_MOSI -1 //#define TMC_SW_MISO -1 //#define TMC_SW_SCK -1 /** * Use Trinamic's ultra quiet stepping mode. * When disabled, Marlin will use spreadCycle stepping mode. */ #define STEALTHCHOP /** * Monitor Trinamic TMC2130 and TMC2208 drivers for error conditions, * like overtemperature and short to ground. TMC2208 requires hardware serial. * In the case of overtemperature Marlin can decrease the driver current until error condition clears. * Other detected conditions can be used to stop the current print. * Relevant g-codes: * M906 - Set or get motor current in milliamps using axis codes X, Y, Z, E. Report values if no axis codes given. * M911 - Report stepper driver overtemperature pre-warn condition. * M912 - Clear stepper driver overtemperature pre-warn condition flag. * M122 S0/1 - Report driver parameters (Requires TMC_DEBUG) */ #define MONITOR_DRIVER_STATUS #if ENABLED(MONITOR_DRIVER_STATUS) #define CURRENT_STEP_DOWN 50 // [mA] #define REPORT_CURRENT_CHANGE #define STOP_ON_ERROR #endif /** * The driver will switch to spreadCycle when stepper speed is over HYBRID_THRESHOLD. * This mode allows for faster movements at the expense of higher noise levels. * STEALTHCHOP needs to be enabled. * M913 X/Y/Z/E to live tune the setting */ //#define HYBRID_THRESHOLD #define X_HYBRID_THRESHOLD 100 // [mm/s] #define X2_HYBRID_THRESHOLD 100 #define Y_HYBRID_THRESHOLD 100 #define Y2_HYBRID_THRESHOLD 100 #define Z_HYBRID_THRESHOLD 3 #define Z2_HYBRID_THRESHOLD 3 #define E0_HYBRID_THRESHOLD 30 #define E1_HYBRID_THRESHOLD 30 #define E2_HYBRID_THRESHOLD 30 #define E3_HYBRID_THRESHOLD 30 #define E4_HYBRID_THRESHOLD 30 /** * Use stallGuard2 to sense an obstacle and trigger an endstop. * You need to place a wire from the driver's DIAG1 pin to the X/Y endstop pin. * X, Y, and Z homing will always be done in spreadCycle mode. * * X/Y/Z_HOMING_SENSITIVITY is used for tuning the trigger sensitivity. * Higher values make the system LESS sensitive. * Lower value make the system MORE sensitive. * Too low values can lead to false positives, while too high values will collide the axis without triggering. * It is advised to set X/Y/Z_HOME_BUMP_MM to 0. * M914 X/Y/Z to live tune the setting */ //#define SENSORLESS_HOMING // TMC2130 only #if ENABLED(SENSORLESS_HOMING) #define X_HOMING_SENSITIVITY 8 #define Y_HOMING_SENSITIVITY 8 #define Z_HOMING_SENSITIVITY 8 #endif /** * Enable M122 debugging command for TMC stepper drivers. * M122 S0/1 will enable continous reporting. */ #define TMC_DEBUG /** * M915 Z Axis Calibration * * - Adjust Z stepper current, * - Drive the Z axis to its physical maximum, and * - Home Z to account for the lost steps. * * Use M915 Snn to specify the current. * Use M925 Znn to add extra Z height to Z_MAX_POS. */ //#define TMC_Z_CALIBRATION #if ENABLED(TMC_Z_CALIBRATION) #define CALIBRATION_CURRENT 250 #define CALIBRATION_EXTRA_HEIGHT 10 #endif /** * You can set your own advanced settings by filling in predefined functions. * A list of available functions can be found on the library github page * [github.com] * [github.com] * * Example: * #define TMC_ADV() { \ * stepperX.diag0_temp_prewarn(1); \ * stepperY.interpolate(0); \ * } */ #define TMC_ADV() { } #endif // TMC2130 || TMC2208
