Trying to find a stepper motor under 1A but with enough torque
Posted by GtwoK
January 07, 2014 04:45PM
I'm having extreme difficulty finding stepper motors to buy. My drivers are only rated for 1A, but every motor I can find has the torque drop significantly once you go under that. I must be understanding something wrong, but what am I missing? What amount fo torque do I ACTUALLY need?
Re: Trying to find a stepper motor under 1A but with enough torque
January 16, 2014 09:37PM
Your drivers are rated for 1A but without heatsink and fan.
My stepper motors are 1.7A and my drivers are also rated to1A but with a heatsink and fan I don't have problems.
January 17, 2014 03:00AM
About the current on the label of the motor, i would rather think of it like a maximum, instead of a target to be hit.
About the current level on the driver chip, we actually change that with a onboard potentiometer.
The torque will be proportional to the said current level. On the label if the max current rating is lower, the max torque will most likely be lower. On the adjustment pot, if we decrease the current then ofc torque is decreased accordingly. So "the amount of torque you actually need" - you will probably find out yourself by adjusting the pot on the driver.
The driver regulates regardless of which motor type is there. In this sense the stepper motor can not draw whatever curent it wants, but motor can only get what the driver gives him. E.g. can have a motor rated for 5A, but a driver rated of 2A and adjust the driver pot to only put 1A in the motor. The point is, you dont need to match these in your purchase. But if you want to look out for something about matching these two current values, then is better for motor rating to be higher than driver rating, at least for one coz the driver rating is probably given as rms.
What you should be careful about instead, is to get motors that are low resistance, e.g. probably something like 1-2-3 ohms and have a current rating of 1-1.5-2A-... and even more. This means the coil has a thick wire, which translates in a low number of turns because its inside same space form factor, so lower inductance. Stay away from high inductance motors, which have more number of turns, hence thin wire, hence lower current rating and ofc higher resistance - this latter type does not match our usual drivers and power supply.
February 10, 2014 09:42AM
So the 2.7volt, 1.8A, 1.5 ohm motors I found might work OK?
February 10, 2014 06:58PM
Yes smiling smiley
February 10, 2014 07:03PM
Great. PS they are Nema-23's. No problem, I have the room for them.
These are similar to the ones I got:
[www.mpja.com]
Edited 1 time(s). Last edit at 02/10/2014 07:27PM by kscharf.
