Motors wont turn same old same old February 21, 2014 04:22PM |
Re: Motors wont turn same old same old February 21, 2014 04:43PM |
Re: Motors wont turn same old same old February 22, 2014 09:17PM |
Re: Motors wont turn same old same old February 23, 2014 06:32PM |
Re: Motors wont turn same old same old February 27, 2014 08:27AM |
Re: Motors wont turn same old same old February 27, 2014 08:33AM |
Re: Motors wont turn same old same old February 27, 2014 04:31PM |
Re: Motors wont turn same old same old February 27, 2014 06:08PM |
tyscof
When I wired my motors I checked to see what what two wires had the most resistance on them and cut the center tap, on the motors the wires are all blue except for the two center taps which are orange, so i cut those off. I then put the two wires next too each other in a 4 prong connector. I wired it so that the outer wire on the motor connector is the outer wire on the 4 pin connector.
PIN1= B-
COMMON
PIN3= B
PIN4= A
COMMON
PIN6= A-
So right now I have it wired that B- will be the outer most wire B+ and A+ are the inner wires with A- on the outside aswell. Is this wrong?
Re: Motors wont turn same old same old February 27, 2014 10:42PM |
Re: Motors wont turn same old same old February 28, 2014 07:36AM |
Re: Motors wont turn same old same old February 28, 2014 08:37AM |
Re: Motors wont turn same old same old February 28, 2014 09:13AM |
jtoombs
Wait... I think I provided you with the wrong information. Now that I looked at my ramps board I realized that I had it wired up so that one coil was on the inner two pins and the other was on the outer two. This is wrong on the ramps board. It should be the pins that are next to each other are each a coil. So 1A and 1B and 2A and 2B go together. It was really confusing to me at first . I probably spent a good two days trying to figure out that this was my problem.
Re: Motors wont turn same old same old February 28, 2014 10:15AM |
Re: Motors wont turn same old same old February 28, 2014 10:36AM |
tyscof
Okay so then I do have my motors wired correctly, I have them as pins order 1,3,4,6. I have the two wires for a coil on one side and two wires for the other coil on the other side. I checked the voltage the motor was getting to make sure and when I put my meter over the two leftmost wires(B+ and B- or wires 1 and 3) and got a voltage of 12.8 and the same when I put it over the other two wires. So could this be a problem with my drivers or board? I don't think it could be my drivers because none of them work but I don't know if that really means anything. I guess we could safely assume the motors are getting enough amperage and that wouldn't be the problem, unless the shaft not moving may indicate that, but it isn't turn able when there is a current on it. It also can't be the motors since all 5 do not work, would the endstops be causing this? I just unplugged them since they were in the way but that shouldn't matter if I'm just jogging the motors right? It should't make a difference with the extruder driver anyway which tries to move but is super weak and can't.
Re: Motors wont turn same old same old February 28, 2014 11:17AM |
Re: Motors wont turn same old same old February 28, 2014 11:25AM |
tyscof
Ok the motors not moving in reverse makes sense now since they are not homed, and No I havent messed around with the steps per mm, in the firmware right? I could see how that would throw off accurate movement but shouldn't the motor still move just the wrong distance? Like if I jog the motor 100 units or connect it to the extrusion driver it should move just not say the exact 100 units right? Or would this stop the motors from doing anything?
Re: Motors wont turn same old same old February 28, 2014 11:53AM |
Re: Motors wont turn same old same old February 28, 2014 12:52PM |
Re: Motors wont turn same old same old February 28, 2014 03:36PM |
Re: Motors wont turn same old same old February 28, 2014 03:51PM |
tyscof
Yep, I set them to around .5 which is right for my drivers, It seems like the y stepper is working great still having trouble with the x now it doesnt want to move again even with the
#define _AXIS_STEP_PER_UNIT {10, 30, 3200/1.25,700} set super low. And if I tell it to move now I can just push it without very much effort even if the vref is set really high, so I think I may have burned it out or it was deffective to begin with, or it may be fine and I messed with it enough in the firmware to set it screwy again. But I think something is wrong with the motor since if I set the x and y axis motor to the same setting the y axis one works well but the x doesnt move at all. And get this when I set the y motor to 53.3 in mm/s it moved fine so I guess the x motor has been deffective all along? I have a question though, in pronterface if you hit your endstop does it say anything in the commands window because when I plug them in they dont seem to do anything, I have it wired so that it is closed with a 4.7kohm resistor connecting the ground and singal wire, when the end stop is hit the circuit is open
Re: Motors wont turn same old same old February 28, 2014 06:03PM |
Re: Motors wont turn same old same old February 28, 2014 07:34PM |
tyscof
Ok so If I set my #define _AXIS_STEP_PER_UNIT higher like to 100 the smaller step like.1 works fine but when I try to hit 1 it just makes a high pitch noise and doesn't move. I set it to 100 because when I set it to 50 it took two hit of .1 to get it to jog once, but say if I try to jog 100 the y doesn't move it just makes a loud high pitch noise, know any cause of this? Likewise if I set it lower it can do the larger jogs but I have to hit the .1 jog like 50 times to get it to move anywhere.
Re: Motors wont turn same old same old February 28, 2014 10:41PM |
