I have Prusa mendel built some time ago.
Arduino + ramps 1.4 + a4988, wades extruder, marlin
Currently my extruder is working ok, but it is set to full step, loud and not precise
When I'm setting to 1/16 on ramps, stepper is turning werrry slow.
Question: If I will adjust pots on driver, will motor spin faster?
I understand that I will need to adjust steps per mm.
But this will be after getting stepper to spin in correct speed
Motor info:
NEMA 17 Stepper Motor Model 17HS19-1684S - Specifications
Frame size 42 x 42mm - NEMA 17
1.8 degree step angle
Length 47mm
Holding torque 44 N.cm (4.4kg.cm, 62oz.in)
Voltage 2.8V
Current/Phase 1.68A
Resistance/Phase 1.65ohm
Inductance/Phase 2.8mH
Inertia 68g.cm
Bipolar, 4-wire
Weight 0.35kg
Step Angle Accuracy ±5%(full step,no load)
Resistance Accuracy ±10%
Inductance Accuracy ±20%
Temperature Rise 80℃Max.(rated current,2 phase on)
Ambient Temperature -10℃-+50℃
Insulation Resistance 100MΩMin. 500VDC
Dielectric Strength 500VAC for one minute
Shaft Radial Play 0.02Max.(450 g-load)
Did some troubleshooting: connected extruder motor to x axis driver witch is 1/16 micro stepping.motor spins ok
with my lcd controller i found Vmax X and Y are 500 but Vmax E is 25.
Is it ok or this needs to be changed??
Edited 2 time(s). Last edit at 02/27/2014 02:00PM by didzix.
