What am I missing March 18, 2014 11:30PM |
Part Number HT17-277 Frame Size NEMA 17 Motor Type High torque Part Number w/Double Shaft HT17-277D Part Number w/Encoder HT17-277D-WAA Part Number w/Encoder & Cover NA Motor Length 1.90 inches Number of Lead Wires 8 Lead Wire Configuration flying leads, no connector Lead Wire/Cable Length 12 inches Lead Wire Gauge 26 AWG Unipolar Holding Torque 43.9 oz-in Bipolar Holding Torque 62.3 oz-in Step Angle 1.8 deg Bipolar Series Current 0.28 A/phase Bipolar Series Resistance 60.0 Ohms/phase Bipolar Series Inductance 128 mH/phase Bipolar Parallel Current 0.57 A/phase Bipolar Parallel Resistance 15.0 Ohms/phase Bipolar Parallel Inductance 32.0 mH/phase Unipolar Current 0.40 A/phase Unipolar Resistance 30.0 Ohms/phase Unipolar Inductance 32.0 mH/phase Rotor Inertia 1.16E-03 oz-in-sec2 Integral Gearhead No Weight 0.8 lbs Storage Temperature -30 to 70 °C Operating Temperature -20 to 50 °C Insulation Class Class B (130 ºC) Maximum Radial Load NA Maximum Thrust Load NA Shaft Run Out 0.001 inch T.I.R. max Radial Play 0.001 inch max w/ 1.1 lb load End Play 0.003 inch max w/ 1.1 lb load Perpendicularity 0.004 inches Concentricity 0.002 inches
68 oz.in 400 steps/rev Bipolar Step Angle (degrees) : 0.9 2-Phase Rated Voltage: 3V Rated Current: 1.7A/Phase 5mm Diameter Drive Shaft Holding Torque: 48N.cm NEMA 17 form factor
Re: What am I missing March 19, 2014 07:44AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
