Stepper motors for the McWire January 20, 2010 01:22AM |
Re: Stepper motors for the McWire January 20, 2010 01:36AM |
Re: Stepper motors for the McWire January 20, 2010 04:43AM |
Forrest Higgs
when you specify a 1.8 degree step stepper motor you are going to have the devil's own time getting it to turn fast enough to do any printing in a reasonable amount of time. Figure that you have 200 steps per revolution and 1 mm pitch on your threaded rod. That means that one step moves you 0.005 mm. If you do 1,000 steps/sec you are going to be moving your axis 5 mm/sec. Getting a stepper motor to do 1000 steps/sec is hard work. Ask Zach or nophead or anybody who's worked with them.
Also, when you are running at 1000 steps/second and more your available torque drops like a stone, so that big holding torque value and all that power isn't getting you very much at speeds high enough to get some printing done in reasonable time frames.
Re: Stepper motors for the McWire January 21, 2010 07:37AM |
Re: Stepper motors for the McWire January 24, 2010 05:49AM |
Re: Stepper motors for the McWire January 31, 2010 04:15AM |
Re: Stepper motors for the McWire February 04, 2010 01:21AM |
Re: Stepper motors for the McWire March 07, 2010 04:23PM |
Re: Stepper motors for the McWire March 08, 2010 01:42AM |
Electric motors and drives: fundamentals, types and applications
Mini-stepping is a technique based on two-phase-on operation which
provides for the subdivision of each full motor step into a number of
‘substeps’ of equal size. In contrast with half stepping, where the two
currents have to be kept equal, the currents are deliberately made un-
equal. By correctly choosing and controlling the relative amplitudes of the
currents, the rotor equilibrium position can be made to lie anywhere
between the step positions for each of the two separate phases.
Closed-loop current control is needed to prevent the current from
changing as a result of temperature changes in the windings, or vari-
ations in the supply voltage; and if it is necessary to ensure that the
holding torque stays constant for each ministep both currents must be
changed according to a prescribed algorithm.
Re: Stepper motors for the McWire March 08, 2010 03:35AM |
Admin Registered: 16 years ago Posts: 13,886 |
Re: Stepper motors for the McWire March 08, 2010 04:13AM |
