stepper motor is getting heat up????? October 06, 2014 12:54AM |
Re: stepper motor is getting heat up????? October 06, 2014 03:28AM |
Re: stepper motor is getting heat up????? October 07, 2014 05:50AM |
Re: stepper motor is getting heat up????? October 08, 2014 07:02AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: stepper motor is getting heat up????? October 08, 2014 02:47PM |
dc42
Stepper motors (apart from very low power ones) should be driven by a constant current chopping controller, which is not what you are using. If the stepper motor is getting to hot, you need to either reduce the voltage it is getting (e.g. by using a lower supply voltage, or putting a resistor in series with each winding), or use a constant current stepper motor driver instead.
What size is the stepper motor, and what is the resistance of each winding? Those figures should give us a clue about what current it needs.
Re: stepper motor is getting heat up????? October 08, 2014 03:00PM |
arshia
what do u mean by constant current driver??? i am using mosfet and obviously they would be constant current ......
nd resistance per coil is almost 3.9 ohms
Re: stepper motor is getting heat up????? October 08, 2014 06:10PM |
Re: stepper motor is getting heat up????? October 09, 2014 07:26PM |
Re: stepper motor is getting heat up????? October 10, 2014 05:49AM |
Re: stepper motor is getting heat up????? October 10, 2014 06:02AM |
Re: stepper motor is getting heat up????? October 10, 2014 06:43AM |
