DRV8825 vs TMC2100 vs THB6128 May 11, 2015 07:26AM |
Re: DRV8825 vs TMC2100 vs THB6128 May 11, 2015 11:57AM |
Re: DRV8825 vs TMC2100 vs THB6128 May 11, 2015 12:58PM |
Re: DRV8825 vs TMC2100 vs THB6128 May 12, 2015 04:21AM |
the_digital_dentist
Keep in mind when you go to higher microstepping ratios torque goes down
the_digital_dentist
Increasing microstepping ratio above 16 in a 200 step per rev motor does not increase resolution, only smoothness of rotation.
Re: DRV8825 vs TMC2100 vs THB6128 May 12, 2015 08:27AM |
Re: DRV8825 vs TMC2100 vs THB6128 May 22, 2015 12:27PM |
Re: DRV8825 vs TMC2100 vs THB6128 May 22, 2015 01:21PM |
Re: DRV8825 vs TMC2100 vs THB6128 May 22, 2015 02:08PM |
You think that this is due to the current?Quote
AndrewBCN
I don't have any of these new drivers but I assume you can adjust the current to the steppers. If so, what is the current you have set for your steppers? What was it previously set to with the DRV8825's?
Re: DRV8825 vs TMC2100 vs THB6128 May 22, 2015 04:05PM |
Re: DRV8825 vs TMC2100 vs THB6128 May 23, 2015 03:46AM |
Poblem solved about shifted layers!!Quote
AndrewBCN
I believe the formula to calculate current is slightly different for the TMC2100 drivers, in this video they have Vref set @ 1.1V:
[www.youtube.com]
Also, did you configure them for spreadCycle mode or otherwise?
Re: DRV8825 vs TMC2100 vs THB6128 May 23, 2015 05:37AM |
mdcompositi
AndrewBCN
[www.youtube.com]
I've set Vref @ 1.1 and now all work very well!!
I suggest you to test TMC2100!!
Re: DRV8825 vs TMC2100 vs THB6128 May 29, 2015 09:15PM |
Re: DRV8825 vs TMC2100 vs THB6128 May 30, 2015 06:45AM |
Re: DRV8825 vs TMC2100 vs THB6128 May 30, 2015 09:32AM |
Re: DRV8825 vs TMC2100 vs THB6128 June 01, 2015 11:28AM |
mdcompositi
Hi guys,
I've installed today on my printer drivers tmc2100
I have a corexy and as electronic I use an arduino mega 2560 with ramps 1.4
I installed the drivers only for x and y and I must say that the improvements in terms of smoothness and quietness of mechanism from the previous configuration (with driver drv8825) is outstanding !!
I also put on the drivers heat sinks and of course I installed a fan!
I immediately printed an empty cube 20x20x10 with excellent results and with good speed!
But in subsequent prints something really unexpected happens to me !!
layers are shifted as if there were losses of steps or even slacks belts and pulleys!!!!
But this is not my case, the mechanics are adjusted very well, indeed, for the avoidance of doubt, I reinstalled the drivers earlier (drv8825) and I did the same prints have more this problem!
So I'm wondering, what's the problem !!
drivers are soldered and installed like picture below
[cdn.instructables.com]
Re: DRV8825 vs TMC2100 vs THB6128 June 02, 2015 08:31AM |
Re: DRV8825 vs TMC2100 vs THB6128 June 02, 2015 08:44AM |
uhrheber
Did anybody ever thought of adding capacitors at the motor voltage inputs of the driver modules?
The capacitors that are already on the boards look very small to me, and I bet that they aren't low ESR types.
The more steps per revolution you make, the higher the pulse frequency gets, and the higher the losses in the capacitors will be.
Not only will the aluminium capacitors degrade faster because of that, they'll also not be able to deliver that much pulce current, resulting in reduced torque and step losses.
When switching from 16 microsteps to 128, you should use way bigger capacitors, with low ESR, and put big ceramic capacitors in parallel. You should even put additional capacitors on the stepper module itself, as the PCB traces and connectors have significant resistances and inductances.
Re: DRV8825 vs TMC2100 vs THB6128 February 16, 2017 10:31PM |
Re: DRV8825 vs TMC2100 vs THB6128 April 20, 2017 05:27PM |
Re: DRV8825 vs TMC2100 vs THB6128 April 20, 2017 05:33PM |
Re: DRV8825 vs TMC2100 vs THB6128 April 20, 2017 05:42PM |
Re: DRV8825 vs TMC2100 vs THB6128 April 20, 2017 05:49PM |
Re: DRV8825 vs TMC2100 vs THB6128 May 12, 2017 02:02PM |
Re: DRV8825 vs TMC2100 vs THB6128 May 12, 2017 06:49PM |
clyevo
So from reading this thread conclusion is microstepping does not increase resolution...
clyevo
and reduce torque compare to lower microstepping.
clyevo
So there is no point of higher microstepping driver beside reducing noise.
Maybe one slight advantage, it move smoothly causing less ripple and better curve movement.
clyevo
Are these conclusions correct? If it is i will stick with a4988 which has higher compatibility with 8bit processor like my atmega 2560.
Wait, can someone please tell me why i should buy the higher microstepping driver? Is it much improvement?
