Motor Only Moves in One Direction!
Posted by joshuafkon
June 08, 2015 11:52AM
Hello!
I'm working on getting my machine up and running using Marlin firmware - but I'm having some problems. The X-axis motor only moves to the left. This is slightly complicated by the fact that I'm using Powerlolu stepper motor drivers
I have searched this forum and tried some of the suggestions with no luck so far -
  • I have removed all the endstops and jumped the endstop pins together - sending M119 shows that all the endstops are open
  • I have tried using the RAMPSTestCode.pde (everything lights up but the motor only moves in one direction)
  • I've even switched out my motors and tried a different RAMPs board.
Does anyone have any experience with the powerlolu stepper driver? I suspect I'm wiring that incorrectly?
I'm particularly unclear about the circled GND and Voltage - I interpreted that wiring diagram as saying that if I'm using an external power supply (which I am - 24V) then don't use those lines at all
Thanks!
Re: Motor Only Moves in One Direction!
June 08, 2015 01:28PM
joshuafkon
Thanks!
That is correct.
June 08, 2015 01:36PM
So, I've been able to get the motor to move in the other direction - sort of. If I switch The AB wires in either of the phases then the motor will move counter-clockwise (but still only that direction)
June 09, 2015 03:18PM
Marlin will not allow you to move any further in a negative direction than your starting point until you've performed a home. I'm not sure if eliminating your end stops will get around this. I'd put the endstops back in play, enter a home command and trip each end stop manually to see if that gives you freedom of movement.
If you move your motors in a positive direction, can you then move them in the opposite direction back to their starting point - if so then that's normal behavior. If you can't move then back ever, then there is something else that's wroing.
