Driver for 42BYGHM810 motor
June 17, 2015 04:14AM
Hi there
I am the owner of 4 pcs. of 42BYGHM810 ( I think ) and am looking for a driver for the motors.
I am having a little problem finding drivers for the motor, the Voltage of 1,92V and Current of 2.4A is what is bugging me sad smiley
My plan is to have an Arduino to drive the motors:
Could any of you suggest a useable driver for me?
The specs i have can be seen below here.
Thanks a lot
Søren
Frame Size: NEMA17
Step Angle: 0.9 degree
Voltage: 1.92V
Current: 2.4 A/phase
Resistance: 0.8 Ohm/phase
Inductance: 1.8 mH/phase
Holding torque: 4200g-cm 60OZ-IN
Rotor inertia: 68 g-cm2
Detent torque: 0.22kg-cm
Number of wire leads: 4
Weight: 0.38kgs
Length: 48mm
Motor Shaft: 5mm
Re: Driver for 42BYGHM810 motor
June 17, 2015 05:27AM
Your problem is that the 2.4A rated current is rather high for the standard low-cost drivers. However, if you don't need the full torque that the motors are capable of, then these [www.pololu.com] or similar should do (you can pick up cheap clones of them on ebay). You will need a 12V power supply for them.
June 17, 2015 05:31AM
Cool, thanks for the tip.
At the moment i just want to drive them, no practical project at the moment.
Would a A4988 also from Pololu work? Have a few of them somewhere smiling smiley
June 17, 2015 06:46AM
theDiver
Yes, that would work. The maximum current you will be able to run the motor at before the driver overheats will be about 1A or perhaps 1.2A, so you will get up to about 40% to 50% of the rated torque.
Never connect or disconnect stepper motors wires to the driver with the power connected, and make sure the connections are secure before you apply power.
June 17, 2015 07:07AM
Thanks again :-)
