Duet compatible steppers January 06, 2016 11:16AM |
Re: Duet compatible steppers January 06, 2016 07:28PM |
Re: Duet compatible steppers January 07, 2016 03:04AM |
dc42
You have the specifications of the motors supplied by RepRapPro wrong. See [www.aliexpress.com] for the correct spec. This motor [www.omc-stepperonline.com] is a close match.
For the Duet (as with most other 3D printer electronics), you should choose motors with rated currents in the range 1.3 to 1.7A.
Re: Duet compatible steppers January 08, 2016 03:06AM |
Re: Duet compatible steppers January 08, 2016 04:29AM |
Re: Duet compatible steppers January 08, 2016 06:46AM |
Gaou
no its not too late but what do you mean by that ? what difference would it make if i had 0.9 deggre steppers ? is it better resolution or more than this ? I am a newbie at 3d printing and i dont have the mechanical and electronics knowledge to think of changes like this . it seems an everest to me to go from 1.8 to 0.9 but if you say it is worth then i have to consider it .
Re: Duet compatible steppers January 08, 2016 12:36PM |
Re: Duet compatible steppers January 13, 2016 01:46AM |
Re: Duet compatible steppers January 14, 2016 03:21AM |
Re: Duet compatible steppers January 14, 2016 04:26AM |
Re: Duet compatible steppers January 25, 2016 10:35AM |
Re: Duet compatible steppers January 25, 2016 03:34PM |
