hello, i have two sets of step motor, one its a miniangle stepper model 23lm-c377-03, 1.8 deg/step 3.8v/phase ,1.15A/phase and the second its a Kp56lm2-097 Unipolar / 2 phases 6 Volts DC (nom) 1.2 Amps / Phase (nom) 2.4 Amps / Motor 1.8 Degree/Step 80 oz/Inch 6 wires: white,black,red,red/white,green,green/white 2 1/4 inch. diameter 2 1/4 inch. length (excluding shafts) Size 2.2 sqi Double shaft NEMA 23 size 11/16 inch Shaft length (each) Made in Japan
well i just build a small cnc router and i like to use those stepper for it. I have an Arduino 2560 and i was think to get a gshield board with a step driver dv8825 to control those stepper. will those step motor work with a gshield and dv8825 driver.
if they do work, what power supply should i get to run fine ???
still noob in this field.
thx for any info.
