Which steppers for DIY Ultimaker 2? July 28, 2016 01:43PM |
Re: Which steppers for DIY Ultimaker 2? July 28, 2016 04:27PM |
Re: Which steppers for DIY Ultimaker 2? July 29, 2016 02:27AM |
Re: Which steppers for DIY Ultimaker 2? July 29, 2016 08:00AM |
harmaasilmä
Great! Now my 3d-printer is not far from finished. Anyway, I have a further question: would this be a good choice for the z-axis? Would it work well with Smoothie/Duet? I would also appreciate some recommendations for the extruder stepper (I'll be using bowden extruder with 1.75mm filament). Thanks again!
Re: Which steppers for DIY Ultimaker 2? July 29, 2016 11:35AM |
dc42
For the extruder, I recommend using a gear ratio of between 3:1 and 5:1 with 1.75mm filament, and a stepper motor with 20 to 30 Ncm holding torque at full current, with a current rating in the range 1.2 to 1.7A (or 1.2 to 2.0A if using the Duet WiFi). I use JK42HS34-1334 motors and an extruder gear ratio of 34:11.
Re: Which steppers for DIY Ultimaker 2? July 29, 2016 02:36PM |
PDBeal
dc42
I'm curious, why the suggestion in geared extruder? Just for more torque at lower current with smaller motors? Or was there some other reason I'm not seeing?
Re: Which steppers for DIY Ultimaker 2? August 01, 2016 03:21AM |
dc42
I can't advise you on the mechanics, but in electrical terms that motor is fine for the Duet, Smoothie and most other electronics.
Re: Which steppers for DIY Ultimaker 2? August 01, 2016 05:08AM |
Re: Which steppers for DIY Ultimaker 2? August 01, 2016 06:44AM |
Re: Which steppers for DIY Ultimaker 2? August 01, 2016 07:31AM |
Re: Which steppers for DIY Ultimaker 2? August 01, 2016 08:04AM |
Re: Which steppers for DIY Ultimaker 2? August 04, 2016 03:26AM |
Re: Which steppers for DIY Ultimaker 2? August 04, 2016 08:33AM |
Re: Which steppers for DIY Ultimaker 2? August 08, 2016 06:19AM |
