MKS LV8729 , a 128 µStep Driver // Any test? November 18, 2016 11:47PM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? November 19, 2016 05:53AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: MKS LV8729 , a 128 µStep Driver // Any test? November 23, 2016 01:04PM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? January 25, 2017 06:29PM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? January 27, 2017 04:52PM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? February 11, 2017 11:18AM |
Anonymous User
Re: MKS LV8729 , a 128 µStep Driver // Any test? March 12, 2017 12:30AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? April 05, 2017 03:24AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? April 05, 2017 04:12AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? April 10, 2017 03:33PM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? May 08, 2017 03:30PM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? May 09, 2017 03:47AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? May 09, 2017 04:51AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? May 09, 2017 05:48AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? May 09, 2017 12:51PM |
Thank you for the reply. I have lowered the Vref to about 0.3V and noise decreased significantly. But still the printer makes noise something closer to drv8825,almost the same. I set jumpers for 1/32 on my mks gen. I am still trying for the best. But I think these drivers are not that good as tmc2100s.Quote
DjDemonD
The vref at 0.4v gives 0.8A so you're running those motors at/near their maximum current handling, they will always be noisy when near that level. The document above has values of vref against current. You should always aim to run motors at around 75% of their max current to prevent excess noise, and heating of the motors in use, which can soften/melt printed motor brackets. For your motors reduce vref to 0.3v or even 0.25v. See if that helps with noise.
The issue with 0.85A motors is that they may not provide enough torque to move larger/heavier printer axes, especially corexy where one motor has to be able to move the entire corexy mechanism by itself on diagonal head moves. 1.68A motors are more commonly used, as most drivers can deliver 1.2A (vref 0.6v on these drivers) maintaining the 75% recommended setting and will generate at least twice the torque.
Also check the jumpers under the drivers carefully to ensure they are set to the microstepping mode you want i.e. 1/16 is the most common setting or 1/32 if your controller can handle it. If they are set to 1, 1/2, 1/4 or 1/8 they are likely to be noisier. The document linked to there shows you the jumper config you need.
If you are not sure what they are set to, ask for 50mm of movement, if your firmware is using the default steps/mm for example 80 for 20t pulleys and gt2 belt and 1/16 microstepping it will move 50mm, if it moves 100mm then its set to 1/8, if it only moves 25mm then its set to 1/32. Adjust your steps/mm to the correct amount for the microstepping you are using.
I'm not sure I'd "measure" resonance but some frames vibrate at certain frequencies, sometimes its loose tnuts/bolts etc... Though I suspect you are just over driving your motors.
Re: MKS LV8729 , a 128 µStep Driver // Any test? May 09, 2017 01:56PM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? May 09, 2017 10:43PM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? May 10, 2017 03:08AM |
I tried fysetc and there is no spreadcycle mode for it as the seller declared to me
Re: MKS LV8729 , a 128 µStep Driver // Any test? May 10, 2017 03:16AM |
Did you solder the tiny CFG1 pad for spreadcycle?Quote
o_lampe
I'm using fysetc too and was able to change the modes by soldering bridges on the underside. ( see thread about TMC2100 in general forum )
Of course, I don't know they are in spreadcycle now, but they behave different.
Re: MKS LV8729 , a 128 µStep Driver // Any test? May 10, 2017 06:31AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? May 10, 2017 03:06PM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? July 20, 2017 08:12AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? July 20, 2017 08:15AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? July 26, 2017 05:23PM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? July 26, 2017 06:35PM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? October 02, 2017 10:47AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? February 19, 2018 08:46AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? February 19, 2018 09:25AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? February 19, 2018 10:37AM |
Re: MKS LV8729 , a 128 µStep Driver // Any test? February 20, 2018 03:40AM |
I have set High Low High (1/32)and I am still skipping X direction on tall items.
