Connecting Stepper Motors and Drivers
Posted by qzai09
December 12, 2016 09:17AM
Recently, I would like to try a project with multiple stepper motors. I am trying to connect the stepper motor as shown in the diagram attached. The stepper motor driver used is DRV8825 Stepper Motor Driver Carrier.
Motor A: [www.omc-stepperonline.com]
Motor B: [www.omc-stepperonline.com]
Motor C: [www.omc-stepperonline.com]
Will there be any problem with the connection? Any suggestion is welcomed.
Thank you.
Best Regards,
Qzai09
Re: Connecting Stepper Motors and Drivers
December 12, 2016 03:54PM
Enable need to be tied low, not left floating
With m0,m1 and m2 left disconnected, your running in full step mode, this is probably not desired
December 13, 2016 01:29PM
Make it simple
Put a GRBL board atop your arduino
[www.synthetos.com]
[www.ebay.com]
12v-30v motor voltage supported
Load GRBL on arduino and start executing g-codes
and spinning the motors
confused smiley
