Unknown specification NEMA 17 stepper motor
Posted by debojitk
August 22, 2017 09:13AM
I found some used stepper motors from streets of our local electronics market, which are in working condition.
All I know about those motors are
1. NEMA 17 form factor
2. 2 phase bipolar (4 wire)
3. coil resistance 2.1 ohm.
Now as per Ohm's law if I assume that its current rating is ~1.5 A (which I think more of a standard in these types of motor), then the voltage rating comes as ~3.15 v (2.1*1.5).
I understand that I have to use constant current chopper driver, that would reduce the driver at standstill mode, and increase voltage while running.
The question is which driver I safely use to drive these motors. Can DRV8825 be an option? If so what psu I should use to drive it. Can I use a Computer SMPS?
Additionally I have a L293d shield. Can I use this shield at least to drive the motor to see it running. Can I add a small hi power resistance with the motor coil in series to achieve this?
Thanks in advance.
Debojit
Edited 1 time(s). Last edit at 08/22/2017 09:13AM by debojitk.
Re: Unknown specification NEMA 17 stepper motor
August 22, 2017 12:21PM
You can almost certainly use them. Don't assume they are 1.5A. Instead, look through this list [www.omc-stepperonline.com] for a motor with about the same resistance and length as the ones you found.
DRV8825 drivers should be OK, however they have problems with some types of motor so are best avoided unless you already have them. L293d is no good.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet [www.duet3d.com].
August 23, 2017 03:36AM
Thanks a lot for your suggestion.
Matching with my spec I found Nema 17 2.1 Ohm bipolar. It says the input voltage should be 2.8 volt.
I read that for DRV8825 the Vmot( min ) is >4v. So how this driver would be able to drive this stepper. I am confused here. Please help.
Thanks,
Debojit
August 23, 2017 11:36AM
debojitk
Thanks,
Debojit
I hadn't seen that part of the datasheet, perhaps they added it in a later revision. I think that limitation is to avoid the known problem with DRV8825 drivers. So pick a different type of driver.
August 25, 2017 08:07AM
dc42
debojitk
Thanks,
Debojit
I was reading through some blogs and post and found that there is a pot to adjust Vref which is related to output current. To keep the current constant it automatically adjusts the voltage to each phase. Could you please confirm if it is the case?
Thanks,
Debojit.
August 25, 2017 02:32PM
Plug-in drivers generally have a pot to adjust the motor current. 3D printer control boards with built-in stepper drivers generally provide for setting the motor currents using a gcode command, which is easier.
