Which motor to choose? 1.8deg 59Ncm vs 0.9deg 46 Ncm
November 24, 2017 01:44AM
So, I'm building my second printer based on the AM8 plans on Thingiverse. I'm thinking of buying either these 0.9deg 46Ncm motors (here) or these 1.8deg 59Ncm motors (here). My current printer uses 1.8deg motors, and I was wondering if I could increase print quality with 0.9deg motors on all axes? To do so, I have to sacrifice 13Ncm of holding torque, and I'm not sure what holding torque value I should not fall under.
Any recommendations?
Re: Which motor to choose? 1.8deg 59Ncm vs 0.9deg 46 Ncm
November 24, 2017 06:26AM
stick with 1.8 for non delta type machines
Overly simplified, using 0.9 does give you more theoretical resolution... but at the cost of half your max speed (twice as many steps/mm and you start to run into atmega limits, unless you also upgrade to 32bit controller)
November 24, 2017 12:51PM
Ah okay, thank you for the information. 1.8 it is then!
