(Another) TMC2130 Short To Ground Topic
Posted by MarkGrindcore
November 20, 2018 11:58AM
So, i am aware that it has been posted thousands of times by now, but no matter what i try, i can't seem to get my TMC2130's to work. I am starting with a brand new MKS Gen 1.4 and steppers that are SPI enabled, i am using 5 of them, the one on the E1 is being used an a second Z axis. I am trying to set up Marlin 1.1.9 but i can't seem to get it to work, i get a short to ground on the Y axis as well as all the steppers read as 0:8:00:00:00 except the Y which reads FFF:FFF:FFF or whatever....Not sure what to do or where to go from here. I am using the standard pin configuration online, am i supposed to set those pins in the Marlin firmware somehow? I am about to create a new harness for the steppers so once i am done with that, i will post a pronterface debug to see if that resolved any issues.
Edited 2 time(s). Last edit at 11/20/2018 11:59AM by MarkGrindcore.
Re: (Another) TMC2130 Short To Ground Topic
November 20, 2018 02:53PM
Y driver error detected:
overtemperature
short to ground (coil A)
short to ground (coil cool smiley
X Y Z E0
Enabled false false false false
Set current 800 800 800 800
RMS current 1436 795 1436 1436
MAX current 2025 1121 2025 2025
Run current 25/31 25/31 25/31 25/31
Hold current 12/31 12/31 12/31 12/31
CS actual 0/31 31/31 0/31 0/31
PWM scale 0 255 0 0
vsense 0=.325 1=.18 0=.325 0=.325
stealthChop false true false false
msteps 256 0 256 256
tstep 1048575 4294967295 1048575 1048575
pwm
threshold 0 0 0 0
[mm/s] - - - -
OT prewarn false true false false
OT prewarn has
been triggered false false false false
off time 0 15 0 0
blank time 16 54 16 16
hysteresis
-end -3 12 -3 -3
-start 1 8 1 1
Stallguard thrs 8 8 8 0
DRVSTATUS X Y Z E0
stallguard X
sg_result 0 1023 0 0
fsactive X
stst X X X X
olb X
ola X
s2gb X
s2ga X
otpw X
ot X
Driver registers: X = 0x80:00:00:00
Y = 0xFF:FF:FF:FF
Z = 0x80:00:00:00
E0 = 0x80:00:00:00
Errortongue sticking out smileyrinter halted. kill() called!
[ERROR] Errortongue sticking out smileyrinter halted. kill() called!
February 03, 2019 02:55PM
Same problem here.
Did you finally figure it out?
