Z Stepper motor not moving on DuetWifi February 05, 2019 11:24PM |
G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Network M550 P"tronxy" ; Set machine name M552 S1 ; Enable network ;*** Access point is configured manually via M587 M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S0 ; Drive 0 goes backwards M569 P1 S0 ; Drive 1 goes backwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S0 ; Drive 3 goes backwards M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation M92 X80 Y80 Z400 E99 ; Set steps per mm M566 X1200 Y1200 Z24 E300 ; Set maximum instantaneous speed changes (mm/min) M203 X30000 Y30000 Z600 E3000 ; Set maximum speeds (mm/min) M201 X1000 Y1000 Z1000 E5000 ; Set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S0 ; Set axis minima M208 X300 Y300 Z400 S0 ; Set axis maxima ; Endstops M574 X1 Y1 Z1 S1 ; Set active high endstops ; Z-Probe M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed ;M557 X40:280 Y40:280 S60 ; Define mesh grid M671 X50:50:250:250 Y60:260:260:60 S1.0 P0.5 ; Heaters M305 P0 T100000 B3988 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S120 ; Set temperature limit for heater 0 to 120C M305 P1 T100000 B3988 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Custom settings are not configured ; Miscellaneous T0 ; Select first tool
Re: Z Stepper motor not moving on DuetWifi February 06, 2019 12:34AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Z Stepper motor not moving on DuetWifi February 06, 2019 02:31PM |
Re: Z Stepper motor not moving on DuetWifi February 06, 2019 09:20PM |
× Warning: motor phase A may be disconnected reported by driver(s) 2 Warning: motor phase B may be disconnected reported by driver(s) 2
Re: Z Stepper motor not moving on DuetWifi February 06, 2019 11:43PM |
Re: Z Stepper motor not moving on DuetWifi February 07, 2019 03:28AM |
Re: Z Stepper motor not moving on DuetWifi February 08, 2019 11:17PM |
