0.9° Stepper - Worth it?
Posted by aamcle
October 17, 2019 11:05AM
I'm planning a Ultimaker clone, I have enough 1.8° degree steppers but I may buy 0.9° motors if they would produce an improvement in print quality.
I can see a potential on the X and Y but what about the Z and extruder they seem less likely?
Atb. Aamcle
Re: 0.9° Stepper - Worth it?
October 17, 2019 12:01PM
deltas: yes it helps
others: no it just limits your top speed. (needs twice as many steps/mm)
Take a look at a reprap calculator
1.8 degree steppers gives you a theoretical 5 micron resolution in XY using standard components
0.9 degree steppers gives you 2.5 micron...
Its unlikely you will see the difference.
Edited 1 time(s). Last edit at 10/17/2019 12:02PM by Dust.
October 17, 2019 01:14PM
Thanks Dust.
I'll use the ones I have.
Aamcle
October 19, 2019 08:06AM
I used them on my CoreXY printer - reduced the noise considerably.
October 22, 2019 04:16PM
David J
With good drivers there is no noise
October 27, 2019 05:27PM
obelisk79
David J
I use a Duet board - which has very good drivers.
Edited 1 time(s). Last edit at 10/27/2019 05:27PM by David J.
