Which Stepper-Motor should I buy confused smiley
Posted by Herr_Schmitzel
December 09, 2019 01:44AM
mir sind vor ner woche meine Motoren abgeschmiert, weil sie in eine ecker gerammt sind (bltouch kabel gelöst) und jetzt muss ich mir neue Motoren kaufen. Ich würde sagen ich kaufe mir einen E3D High torque für die z achse und 2 compact but powerful für die x und y achse. Irgendwelche einwände oder vorschläge was besser wäre? LG - Daniel
my motors broke a week ago because they rammed into a corner (bltouch cable unbound) and now I have to buy new motors. I would say I buy an E3D high torque for the Z-axis and 2 compact but powerful for the x and y-axis. Any suggestions that would be better? Thanks for your help - Daniel
Re: Which Stepper-Motor should I buy confused smiley
December 09, 2019 02:29AM
What printer do you have, what electronics, and what stepper drivers?
December 09, 2019 02:51AM
I have an heavily modified Ender 3, an skr mini e3 with tmc 2208/9 not quite sure
December 10, 2019 02:31AM
Does it use 12V or 24V power?
December 10, 2019 08:00AM
it uses 24V
December 11, 2019 01:51AM
Both those motors are rated at 1.68A. It's usual to run stepper motors at a peak current between 60% and 85% of rated current. Above about 85% they get too hot. So for those motors, that's about 1A to 1.4A. That 1.4A is a little high for TMC2208 drivers, but possible with good cooling. Should be no problem if your drivers are TMC2209.
Edited 1 time(s). Last edit at 12/11/2019 01:52AM by dc42.
December 12, 2019 12:23PM
my drivers are tmc 2209 i looked it up in the specs, so should i buy them?
December 12, 2019 03:43PM
Yes, those motors should work well with TMC2209 drivers.
December 18, 2019 05:27AM
I already Said that i have a heavily modified ender 3
December 19, 2019 05:08PM
Herr_Schmitzel
Sorry, "chidaoking3" was a spambot. Removed and deactivated.
Edited 1 time(s). Last edit at 12/19/2019 05:08PM by Ohmarinus.
http://www.marinusdebeer.nl/
