All Nema17 and similar steppers
Posted by rflulling
April 09, 2020 04:17PM
I know there are many models. Like, every one who makes a motor has their own variant. There is literally no end to the possibilities. I think.
I am working on a project that will be made available to others, when completed...
-Will identify compatibility issues with motors and drivers.-
I need, please post as many Models of Stepper motors as possible.
Whatever you use, have used, have researched.
Please reply and add the models you have found to the list. Thanks!
REQUIRED: Model Number, Voltage, Amps/Current, Inductance,
If you have it: Steps, Angle, Inertia, shaft Length, shaft Diameter, shaft modeling,
Where you found it, helps but is not required.
Edited 1 time(s). Last edit at 04/09/2020 06:02PM by rflulling.
