nema17 moves only one step
Posted by Hexentric
July 14, 2021 12:25PM
Hi, can anyone explain why stepper motor in extruder seems to take only one step?
(I heated it above cold extrusion limit)
After that it rotates freely.
There is same problem in two printers but 3rd printer works fine with same marlin setup.
stepper driver is ok, wiring is ok, motor is ok...
I also tested E1 slot (instead E0) with same result.
setup: MKS GEN L 2.1 // marlin 1.1.9.1 // A4988 (16 microstep)
Re: nema17 moves only one step
July 18, 2021 09:50PM
Found solution.. there actually was problem in motor wiring
Just cross connected two wires ABAB <--> AABB
Edited 1 time(s). Last edit at 07/18/2021 09:50PM by Hexentric.
