Hi there,
I have DM556T drivers (
https://www.oyostepper.com/goods-112-Digital-Stepper-Driver-18-56A-20-50VDC-for-Nema-23-24-34-Stepper-Motor.html)
and I'd like to get NEMA 34 series motors for them. I have these two in mind and I'm not sure if I could get the stronger one considering the drivers.
https://www.oyostepper.com/goods-401-Nema-34-Stepper-Motor-70Nm-1001ozin-w-Brake-Friction-Torque-40Nm-566ozin-.html
https://www.oyostepper.com/goods-510-E-Series-Nema-34-Stepper-Motor-Bipolar-18deg-120-Nm-169968ozin-60A-86x86x1515mm-4-Wires.html
Or do you think that even the weaker one is on the edge and I should go even lower?
Controlled from PC via LPT port. It will be powered by a 36VDC switching power supply. Designed to drive the axes of a CNC router with a floor plan of 0.7 x 1.2 m (2x Y axis, 1x X axis, 1x Z axis), ball screws with a pitch of 5 mm. Wood "alloys" will be machined
