Y motor ticks after stopping
Posted by Progr3ss
December 31, 2024 04:13PM
Hi all,
I think I am missing something simple here, I hope someone can help.
I have put together a Bear Prusa clone, kinda. Anyway, I printed some parts and assembled it mostly like a Bear. It is using Ramps 1.4 and Drv8825 drivers.
My issue is that the Y motor has some clunkiness sometimes, then the printer errors and has to reset. If I home the printer, sometimes it stops fine, then starts ticking about every second for a minute or two before needing to reset.
I have run it without the y belt and get the same symptoms.
I have swapped driver boards, both Drv8825 and the A4988. I have swapped stepper motors. I have swapped the ramps board. I have not swapped the Mega board. I have isolated the wire to the stepper so no cross talk.
I have adjusted the voltage. Changed the step settings from no microstep to 1/32. Set steps per mm to various things to account for weird missed steps.
It is only on the y. The heat sink gets hot and the motor whines.
I don't know what I am missing.
Thanks Scot
VDX
Re: Y motor ticks after stopping
January 01, 2025 12:22PM
... could be EMI (Electro-Magnetic-Interference), whats causing wrong impulses on the STEP input ... would be reduced with shielding the cables ...
Viktor
January 08, 2025 04:14PM
Well I was able to figure it out, kinda.
It turned out that the Mega board was the problem. Once I swapped out the arduino clone, it started functioning correctly.
Thanks for all the views. Is there a way to close this post?
Scot
