Dual driver, single microcontroller?
Posted by danx3
October 04, 2011 02:59AM
Hi!
Is possible to use dual pololu A4983 driver for control 2 stepper but with a single DIR&STEEP signal?
Attached a a schema about needed.
Sorry i'm don't know about electronics sad smiley
Thanks!
Edited 1 time(s). Last edit at 10/04/2011 02:59AM by danx3.
open | download - dual_driver.JPG (66.1 KB)
Re: Dual driver, single microcontroller?
October 04, 2011 07:39AM
Do you want the 2 steppers to perform the same moves always ?
If so you could wire these both to a single pololu.
October 04, 2011 09:03AM
Yes, its for same moves, but exceed 3A and pololu drivers max is 2A Each stepper is 3.6V 1.7A/phase
Maybe a 4A driver with same pinout as that pololu driver? where to find?
October 07, 2011 10:32AM
I believe just stacking boards has worked for some people, search the forum. Have you tried wiring them in series?
October 31, 2011 10:27AM
On re-read this makes less sense than in my head. Wire the motors in series if NOT using two boards. If you use two boards you need to wire them in parallel.
