I can do up to 5.5" cubed print volume, the print support generation of this printer is excellent so I can do prints that might be otherwise difficult to pull off on a reprap. .20mm - .40mm in .05 mm increments, 20/40/60/80% infill, I can remove the generated supports after printing or leave them for you if you prefer.
I have 8 different colors of ABS at the moment and can offer quick quotes if you send me the STL and desired layer height / infill. I also offer very reasonable design work if you only have technical drawings.
Thanks!
goopyplastic@eneat.com
Edited 5 time(s). Last edit at 09/03/2012 08:36PM by goopyplastic.
