Print these heads?
Posted by Penny Garfunkel
Print these heads?
January 13, 2012 01:07AM
I need some heads printed.
These aren't the heads I want printed, but they're similar models. I just wanted to know if these could be printed or if I need to modify them somehow? If so could I have a price quote for approximately 4 heads?
I would want the heads to be approximately 2 x 2 inches. Hollow, not filled.
2 models attached in .stl form.
Thanks in advance!
open | download - head1.stl (599.1 KB)
open | download - Model2.stl (599.5 KB)
Re: Print these heads?
January 13, 2012 10:41AM
The .stl needs to be a solid object to print, not just a surface.
Do they need to be hollow, or just you want to minimize the cost?
www.Fablicator.com
January 13, 2012 12:04PM
Well I was trying to make a bobblehead. How would you suggest I go about doing this? I guess they could be solid and I could carve out the negative space needed.
January 13, 2012 12:24PM
Making them solid and carving out is the right approach I think. That way you can also build in some way of mounting the spring, too.
www.Fablicator.com
January 13, 2012 02:16PM
Okay. Would this work?
open | download - isthisasolid.zip (489.1 KB)
January 13, 2012 02:29PM
If you can, try to avoid the unconnected triangles like shown here.
Can be fixed by software anyway, but will probably not end up being what you'd like.
January 13, 2012 03:06PM
Yes I was just wondering if that object was solid and could be printed out? Or does it need to edit them further? It is not the object I want printed I am just seeing what I have to do to get them in the proper format.
All help is appreciated, you guys are great, thanks!
January 13, 2012 05:14PM
Probably printable like that, yes.
For a reprap , maybe a last edition to make sure the underneath is absolutely flat.
Otherwise try a powder sintering process (like shapeways.com) as it doesn't need support at all.
April 19, 2012 05:05PM
Hi there,
I found a post you made on RepRap.org for some prototyping and small production runs. Did you still need help with that? M Industrial
Design has the capabilities to do that for you. Let me know.
Thank you,
Jeremiah Smith
M Design
818-840-0640
jeremiah@idbym.com
