Can someone give me a quote for this - dimensions in mm
Posted by generalenthu
January 09, 2012 02:13AM
Can someone give me a price for this prototype. I am a total noob and am not even sure if this can be printed on reprap. the dimensions are in mm.
I can modify the design, if it helps print the big upside down part more easily. but there still are some semi-arches that have to be printed without support. Please let me know.
open | download - prototype.stl (225 KB)
Re: Can someone give me a quote for this - dimensions in mm
January 09, 2012 12:04PM
As is, it can't be printed without support. Is there a good reason automatic support is out of the question?
The unsupported crosspieces could be printed if there was structure under the ends of the 'bridge.' We cannot make non-straight lines in space without using the generated supports.
Edited 1 time(s). Last edit at 01/09/2012 12:08PM by Andrew Diehl.
www.Fablicator.com
January 10, 2012 09:36PM
Here is a simplified version that doesn't probably need support. Please let me know about this one.
open | download - prototypev2.stl (188.5 KB)
January 13, 2012 08:02AM
That version should be printable without any support.
The half arches might need some little post-cleaning depending on the machine and the operator.
January 13, 2012 11:49AM
The original file you posted is $25.00+shipping.
January 19, 2012 09:06PM
I am getting it printed at shapeways for $15 including shipping - material is WSF. I was hoping that I might get a lower price here as I need some larger sized parts and shapeways was charging an arm and a leg for those models
January 20, 2012 02:20AM
To be honest 25$ seems a bit high IMO - but I never tried selling printed parts, so don't take my word on that.
January 20, 2012 10:36AM
The 25 was for it printed with a dimension machine/materials from what I can tell. which explains some of the cost.
www.Fablicator.com
January 23, 2012 10:47AM
Andrew Diehl@ Yep. I print on on either a dimension or a fortus FDM machine.
Stratasys ABS and support material is $~140/lbs
Stratasys or 3D systems would charge you ~$150!
January 29, 2012 01:03PM
On a reprap I can do this for 5€ plus shipping - but you won't get the same finish quality that a Stratasys can offer.
