Need a small, plastic, part made
Posted by joehms22
September 06, 2012 12:37PM
I'm looking to have this part produced (machined/printed/whatever), if the lip around the bottom is an issue, I also have a design without it, although it is prefered. From my estimates, it is around 18 ccs of material ~ 1 cu in.
It should be in black, if possible, and needs to be made from plastic because the part must bend for the latch to be released.
If you're able to make it, send me an email and quote back at joehms22[at]gmail[dot]com
Thank you!
- Joseph
open | download - Tandy Battery Door.stl (7.5 KB)
Re: Need a small, plastic, part made
September 07, 2012 04:43AM
That stl unit is inches, isn't it ? Read in mm it it something like 3 by 2,5 mm big only.
September 07, 2012 04:56PM
I'm not entirely sure. I designed in mm and exported, but I don't know what the conversion in MeshLab did to the piece.
I may have found someone to print it as well.
September 21, 2012 01:47PM
Got the part printed, thanks for everyone that wanted to help!
