Can someone mill my bearing housings (Aluminium/Steel)?
Posted by Waka
November 07, 2016 10:49AM
I'm designing the powder spread for an SLS Printer and need some aluminium/steel block housings for my bearings.
The bearing are these:
Iglidur H1 Flange.
Basically I'm looking for a block of Aluminium/Steel around 40mm x 20mm x 20mm. with a hole drilled for the bearings through the center of the block, one flange bearing will be fitted into each end of the block. Also 4 bolt holes drilled into one of the long 40mm sides for gantry to be screwed onto.
Thanks,
Waka
Re: Can someone mill my bearing housings (Aluminium/Steel)?
November 17, 2016 05:24PM
Hello,
I ve send you a pm
