Cutting STL files
January 12, 2014 02:02PM
hello, i am looking for someone to cut some stl files to fit a home 3D printer 225x15 (flashforge)
some of the files can fit in the build area but the base is not flat so, it will require cutting in half for a better print quality.
please contact me with your price after you check the files, some of them require no cutting its just i didn't want to delete them from the zip file.
[www.dropbox.com]
regards
Re: Cutting STL files
January 13, 2014 02:28AM
Download netfabb Basic Studio and do it yourself, it's EASY!
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
January 13, 2014 04:17AM
thanks for your reply, i tried but it is for paid users only here is a screenshot
Edited 1 time(s). Last edit at 01/13/2014 04:18AM by rebuilder.
January 13, 2014 05:16AM
(removed)
I use netfabb Studio Basic to cut STL files all the time!
On the right hand size adjust the z slider to the position that you want to cut and then press the "Execute Cut" and then the "Cut" bottom on the bottom right-hand side of the window.
On the top right hand side you can select cut 1 (or cut 2) and then export it as STL.
You can also perform multiple cuts.
What the basic version can not do directly is an angled cut e.g. 45° Z, BUT you can workaroud this by rotating the part 45° in X (or Y) and the doing a flat Z cut.
As an example see the Pirate Skull from Thingiverse below:
Edited 3 time(s). Last edit at 06/05/2014 05:29AM by thejollygrimreaper.
Bob Morrison
January 13, 2014 08:49AM
thanks man i will give it a try
Edited 1 time(s). Last edit at 01/13/2014 08:49AM by rebuilder.
April 05, 2014 06:24PM
need a thanks button - good show Bob Morrison!smileys with beer
