Vertex-foot cast in aluminium May 16, 2012 06:49PM |
Re: Vertex-foot cast in aluminium May 17, 2012 04:17AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Vertex-foot cast in aluminium May 17, 2012 08:05AM |
Re: Vertex-foot cast in aluminium May 17, 2012 10:35AM |
Re: Vertex-foot cast in aluminium May 17, 2012 03:08PM |
I made a wooden cope and drag (2 wooden frames basically) and made a negative in sand with the wooden pattern. 'myfordboy' on YouTube has excellent videos on the subject.Quote
Traumflug
Looks good, flashnet. I'm likely not the only one interested in reading what you use to make the mold.
martinprice2004
1) Reduce the thickness in certain areas. Aluminium casts better when the part has uniform wall sections.
2) Have raised bosses around the holes. This way you can flash machine them off quickly to make a very accurate part.
3) Re engineer it so it uses less material. You could drill the wooden master and rework it.
4) Increase the corner radii to improve casting.
5) Extend the casting along the rods, so it increases the rigidity of the reprap machine.
As you have CNC facilities, have you considered machining a tool directly and casting the aluminium directly in the steel mould?
What sort of gas lance do you use and what cupola. Where do you get this from?
Re: Vertex-foot cast in aluminium May 17, 2012 04:03PM |
Re: Vertex-foot cast in aluminium May 28, 2012 11:53PM |
Re: Vertex-foot cast in aluminium May 29, 2012 07:56AM |
Re: Vertex-foot cast in aluminium May 29, 2012 10:28AM |
Re: Vertex-foot cast in aluminium June 01, 2012 06:09PM |
