A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup February 03, 2014 05:13AM |
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup February 05, 2014 08:35AM |
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup February 07, 2014 02:27AM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup February 07, 2014 05:49AM |
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup February 07, 2014 09:03AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup February 07, 2014 09:36AM |
Mecatronic
Reviewing the software we do not appreciate any major defect so we analyze the mechanical design.
The belts were tight and the motors adjusted to the correct current.
The guides apparently swinging well.
We were searching what could happend in CNC forums and we found that is a frequent problem generated by belt backlash.
It usually happens when the motor change direction.
But belts were new and properly tensioned so we could not improve too much.
Finally we modified the firmware in order to compensate the backslash.
We add a few extra steps to the motors when they change direction.
This type of adjustment is usual in CNC software.
The other problem was that at certain speeds the lines appeared as bitten.
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup February 07, 2014 10:57AM |
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup February 07, 2014 12:07PM |
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup February 07, 2014 01:22PM |
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup February 07, 2014 02:57PM |
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup May 19, 2014 11:38AM |
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup September 26, 2014 11:06AM |
Re: A PCB printer for photoresist which uses a PHR-803T Blue-Ray pickup October 07, 2014 07:43AM |
