My first full bed print 350mmx225mm (14x10")
Posted by RichardSalinas
September 29, 2012 12:46PM
I had a successful test using my full bed size of 350mmx220mm. You can see it here:Blog
Re: My first full bed print 350mmx225mm (14x10")
October 01, 2012 01:51AM
Thats Impressive!
Quite a unique Design you have there, is it based on any current designs, or is that your own.
Also what material did you use?
October 01, 2012 09:44AM
ABS 3mm. The design is basically the WhiteAnt 3d printer / CNC machine designed by Patrick Hood- Daniel and can be found at BuildyourCNC. I made the print bed bigger, changed electronics, extruder, etc. I'm waiting on linear rails so that I can replace the y-axis system. I plan to build a heat chamber and other systems in the near future. By the time I'm finished it will be deceptive to call it a WhiteAnt.
October 15, 2012 04:02PM
Not sure why I only just thought of this to solve the shrinkage issue -
Can you over extrude the first 10 layers to compensate for the shrinkage? How about printing the base with "Baffles" to act as a sort of thermal expansion zone for the first few layers?
The less dense the part is printed, the less shrinkage you will see, right?
Measure once, Cut twice, Print 3 times.
