? - MDF build platform
Posted by Mogal
October 06, 2012 09:44PM
Hello,
Just wondering how MDF is going to be for a carrage?
I'm working on a prototype, and MDF was easiest to try first...
But the wieght of this thing is starting to add up.
My best guess, is that it's about 2lbs. What's a good weight?
Another question is, how does MDF hold up to the heat?
It's a silicone heatbed, so it needs a rigid base for support.
The glass I have is 3mm thick, untempered, will it be ok for the bed?
Any feedback on what I have would be muchly appreciated!
Oh, the MDF I used started out at 1/2"
Thanks,
Chris
Custom all metal CoreXY
- Duet 2 Wifi w/ PanelDue 7i
- 330mm x 360mm x 500mm
- 750w Silicon heater
Custom Mendel90
(Backup printer - Old reliable!) - Sold
Re: ? - MDF build platform
October 07, 2012 06:25PM
Anyone?
Custom Mendel90
October 07, 2012 09:11PM
Hi Mogal, it is a good material for a prototype. But i think that the humidity and heat will generate problems in the future.
I t is better than ABS plastic parts, but i think that the aluminium will be the best. With little height and weight.
The wood fiber does not disperse the heat.
October 12, 2012 06:14AM
i use it in about the same way as you do, works fine for about 6 months now.
just give it a small layer of paint to control the humiditie but it wont be that big a deal. Maybe only a little height difference of the table after a period of time
October 12, 2012 11:23AM
Think that the paint may be flamable. With heat, it iwill be a problem.
October 12, 2012 08:11PM
Yea, I was thinking that as well, but a high heat paint I think would be ok?
I will be painting everything when done, to help keep the MDF stable....
I like the bed design I've done, but have to redo the framework sad smiley
So for you silicone heatbed users, what are you doing to support it?
Custom Mendel90
tosjduenfs
October 15, 2012 06:23AM
you can use high temp grill spray paint. It is good to like 1200 degrees F.
