Stabalised camera gimbal for drone.
Posted by Vince
November 05, 2013 05:44PM
Have recently finished a gimbal to mount a sony nex5 on an airbourne platform with printed parts and carbon.
Also many parts on the octacopter were also made on the printer.
More info on gimbal here.
Camera gimbal
And octacopter here.
[diydrones.com]
Example of video from stabalised gimbal shot on Dartmoor.
Dartmoor
Re: Stabalised camera gimbal for drone.
November 08, 2013 09:03AM
Does it do stuff with the motors to avoid vibration or does the frame somehow do that, or does the copter really not vibrate much? I think the first of those? If so how are those motors controlled?
November 08, 2013 09:34AM
Those are 'big' questions.
The multicopter 'drone' community is constantly searching to reduce vibration, both for camera equiptment and because the flight control units can be affected by too much vibration. I have built my (4 so far) machines using silicone o ring suspension systems. I am getting some of the lowest vibrations ever recorded but still get a little shake sometimes. More work to be done. This electronic camera gimbal will remove the movement of the copter but not much vibration. I am currently printing another one with a seperate suspension system but soft mounts can sometimes make it worse. Its all experiment.
There are a number of Flight controllers. on the market from about £40 to £1000s. I like the APM from 3DR from diydrones which is about £150. They sense the copters movement and control the motors to keep it stable. You can use them for a totally automatic flight (programmed via PC) of you can fly it like a normal RC helicopter, and many other modes to make flying it very easy. You can use them on a normal plane with wings or on multicopters.
It can be very confusing at at the beginning.
Vince
November 15, 2013 08:01PM
Jasper1984
To answer your question directly, a gimbal keeps the camera in what ever position you point it, regardless of copter position. It does that with a controller involving gyros and accelerometers. Vibrations are a separate issue.
February 05, 2014 02:46PM
I am currently building my first printer for use with my Quad. This looks like an awesome gimbal, have you or will be making the stl files public?
