WD-11 vacuum tube base March 14, 2015 08:51AM |
Re: WD-11 vacuum tube base March 14, 2015 09:52AM |
Re: WD-11 vacuum tube base May 26, 2015 07:32AM |
Re: WD-11 vacuum tube base May 29, 2015 07:05PM |
the_digital_dentist
I used to replace old electrolytic caps by taking the guts out of the old ones and installing newer, more modern, always smaller caps of equal or greater voltage and capacitance ratings. I also replaced all paper/foil/wax capacitors with polyester caps and then rewired with teflon insulated wire.
Re: WD-11 vacuum tube base May 29, 2015 07:19PM |
Funny, I tend to do exactly the opposite - I figure if I can't get it working, it's not worth restoring the cabinet!Quote
the_digital_dentist
Nice! I used to do a lot of old radio restorations, too. 3D printers are great for replacing things like buttons and knobs that are lost/broken and hard to find.
I usually started with refinishing the cabinet, because if that wasn't possible, there wasn't much point in rewiring the chassis. It also provided inspiration/motivation to do the rewiring. I used to replace old electrolytic caps by taking the guts out of the old ones and installing newer, more modern, always smaller caps of equal or greater voltage and capacitance ratings. I also replaced all paper/foil/wax capacitors with polyester caps and then rewired with teflon insulated wire. Tested and replaced bad tubes, too, of course (I have a TV-7 tester I picked up at a swap meet for $50 before the tube audio nutz pushed the price on all things tube related through the roof). The final step was to tune up the set using the old service instructions from the Beitman's manuals. Most of the time I got them working as good or better than new.
Re: WD-11 vacuum tube base June 02, 2015 09:08AM |
Re: WD-11 vacuum tube base June 02, 2015 05:48PM |
