A better 300 colour thingy
April 07, 2016 04:21AM
Following on from my first attempt which was just a simple cylinder, I printed this using the same technique. I can't and don't claim any credit for the design. It was this item [www.thingiverse.com] which I downloaded from "thingiverse". I'll put a picture on there too when I get time.
I downloaded the "solid" version and sliced it with no top, 3 perimeters and no infill. Then ran the script on the resultant gcode file to get the colour change every layer. Having lots of "nooks and crannies" means that the "toothpaste" effect of the diamond hot end gives vertical bands of colour as well as horizontal. What I mean is that some of the the "valleys" are different colours to the "peaks".
The total height is about 125 mm and colour change is ever 0.3 mm layer, so after 90 mm (300 layers), the colour pattern repeats.
I thought it came out rather well.
open | download - Julia Vase 1.jpg (194.4 KB)
open | download - Julia Vase 2.jpg (246.2 KB)
open | download - Julia Vase 3.jpg (228.8 KB)
Re: A better 300 colour thingy
April 07, 2016 04:22AM
Wow!
April 07, 2016 04:47AM
smileys with beer
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
April 07, 2016 11:20AM
April 07, 2016 02:34PM
Molto Melting Molto Colore smiling smiley
April 07, 2016 09:47PM
Very very nice
April 08, 2016 04:36AM
It looks really awesome, but the color mixing isn't working very well. Somehow unpredictable...
The transition from yellow to red should show some orange, but it seems to show red OR yellow instead.
Is the color the same inside and outside of the part? Or is it red inside and yellow outside and vice versa?
Is it the original diamond hotend?
April 09, 2016 05:34PM
o_lampe
I wonder if that's due to the colours being mixed? I don't know what the OP is using, but maybe they're Red, Green, Blue where Cyan, Yellow, Magenta would be better? Or maybe one of the colours isn't the exact right hue?
April 09, 2016 10:33PM
Very effective and striking print. I'd love to try that one day.
April 12, 2016 09:24AM
o_lampe
Yes, you should take a look at the text I wrote about the first "300 colour thingy" I posted. The issue is that the filament comes out like "stripey toothpaste" rather than being fully mixed. So, it all depends on what "side" you view the object from. I printed a 3 side pyramid with equal mix ratio of Red, Gold and Black. The resultant object has three different coloured sides - Dark Red, Bronze and "mostly Black". So, there is Orange in this 300 colour thingy but you need to view it from the "side" where the Blue filament enters the nozzle. Otherwise it has either a Red or Yellow bias depending on the viewing angle.
Actually I quite like that effect but if you want to achieve a precise, even colour when viewed from all angles, then this probably isn't the way to go about it. What you'd need to do is melt the 2 (or 3) colours and somehow stir them together before they exit the nozzle whilst still keeping the mixing chamber as small as possible so that you can quickly switch between colours.
RepRap.Me have advised me that the "toothpaste" effect can be eliminated by using translucent filaments. I'll give that a go when I get time.
April 12, 2016 09:47AM
frankvdh
o_lampe
Yes, the mixing is down to the "toothpaste" effect I described before. RepRap.Me tell me that using translucent filaments will cure this but I haven't yet tried it. The colours I used were bright Red, bright Yellow and pale Blue (as that was the only Blue I had). Actually that's not true. I did have a dark Blue but it was from a different manufacturer and didn't mix well at all. Maybe there was something in the chemical make up of this filament other than just the colour pigment. This may also be something I need to be careful of but I need to do more testing to be sure.
For full true colour mixing I reckon we'd need Cyan, Magenta and Yellow but also Black (CYMK). Then of course, as we are not printing on paper, we'd need White as well. That would take care of the hue and contrast but as we always have to mix ratios that add up to 100%, we'd also need a clear filament to be able to adjust the saturation. So, I reckon we'd need a hot end that will take 6 colours and have the ability to somehow stir them all together well before they come out of the nozzle whilst keeping the mixing chamber as small as possible. But then of course, we'd also need 6 extruders ...........I think I'll just stick with what I have.
April 14, 2016 10:42AM
Would a longer melt zone allow the colors to mix better? I would think it would since the filament would be spending more time in the heating area of the nozzle.
greghoge.com
HUGE 3D PRINTER PARTS SALE!!!
April 14, 2016 01:24PM
gmh39
Personally I doubt it. If you've ever tried mixing two or more colours of paint you'll know that they need to be stirred together. It doesn't matter how long they sit side by side. Increasing the melt zone would also increase the volume which will likely cause more problems. It would increase the amount of filament that needs to be extruded when switching from one colour to another so the colours would tend to run into each other unless you use large sacrificial towers.
April 14, 2016 03:00PM
I wonder about threading the inside of the nozzle, so that the molten filament swirls as it comes out?
April 15, 2016 01:26PM
frankvdh
That might work. I doubt if you could put a thread in a 0.4mm hole though. Maybe some kind of helical mixing chamber prior to the actual nozzle might work, but then anything which increases the volume of the mixing chamber is going to have a negative impact when changing colours quickly.
Another thing I wondered about is what effect (if any), different layer heights may have and/or slower print speed. I have my machine set up for just about the fastest print speed I can get away with. - Something else to play around with when I get time.
April 16, 2016 03:34AM
The size of a chamber is only relevant because the slicers are not up to the multicolor task yet. Only the outer perimeters have to have a defined color while the rest( like infill and support ) could act as color change area too. The slicer would need to know how much filament has to be extruded before the "new" color is mixed.
With a bigger chamber I would ignore the higher filament cost if I get a sharp and true color change as benefit.
April 16, 2016 07:09AM
o_lampe
That works for some models, but assumes that colour changes only happen in Z. For colour changes in the XY plane things get a bit more difficult, although... I guess I'm making assumptions too smiling smiley Maybe it would be possible to print a segment of 1 colour, move away to print some non-visible area or into a purge area and then return to continue the perimeter in the new colour. Man, there sure is a world of possibilities to explore here!
April 16, 2016 12:39PM
JamesK
o_lampe
Yes, that's the "normal" way of doing it especially if you have separate nozzles. This is where I came in with the original RepRapPro Tricolour. In that case, you need to define each hot end as a separate tool. Because each one has it's own heater, you have to set the unused nozzles to a lower standby temperature to prevent filament from oozing when they are not in use. Then, when you want to change to a different tool, you need to heat it to it's operating temperature and cool the unused tool to it's standby temperature. All this heating and cooling means that you need to print a sacrificial tower to get the filament flowing nicely before you print the object proper. I believe Cura has the ability to provide sacrificial "wiping" towers but I've never tried it. It can be done using Slic3r. It is my understanding that Slic3r prints objects in the order that they are added to the platter. So you can have tower colour A, object colour A, tower colour B, same object colour B, tower colour C, same object colour C etc. In actual fact, just using different coloured filaments in each extruder with no mixing, I've printed a few 2 and 3 colour objects with different colours on the same z layer without using towers, and because of the very small chamber, there is very little "bleeding" between.
Of course, none of that gets around the "striped toothpaste effect" when mixing filaments but as I've said before, I quite like it. Lets face it, if you have a 300 colour object it's going to be purely decorative so having different shades of colour on different sides, adds another dimension to the colour scheme.
And of course, sharp clear colour changes are perfectly possible by not trying to mix colours together. Instead, simply define 3 tools which share the same heater but different filaments and switch between them. Of course, you are then limited to 3 colours. As long as you slicer does the inner perimeters first and the object is large enough, any "mixing" happens out of site (or you could use towers as above).
Maybe the future is to fire small droplets of filament, rather than a continuous bead, in a similar fashion to how an inkjet printer works. Then we could have some fun............
April 16, 2016 05:29PM
JamesK
While that's certainly true in general, it doesn't matter too much when printing cylinder-esque objects like the example shown. If all the colour changes happen at the nozzle exactly 10mm (say) after the change is made, and all printing is done in a(say) a clockwise direction, then all that happens is that the colour change is rotated by 10mm around the perimeter of the object.
Edited 1 time(s). Last edit at 04/16/2016 05:30PM by frankvdh.
April 17, 2016 04:12AM
frankvdh
JamesK
That's what I meant! If the slicers would know the "color mixing offset" it would be able to print infill and support or if this is not an option print a wipe/dump tower.
Edited 1 time(s). Last edit at 04/17/2016 04:12AM by o_lampe.
April 17, 2016 05:28AM
frankvdh
JamesK
That's true but also if you have 2 or more perimeters, the inner perimeters get printed before the outer perimeters so, providing the object isn't too small, then by the time the outer perimeters are printed, the new colour is correct. At least that's what I have observed using slc3r - I can't say what other slicers do.
