E-Waste Extruder
August 01, 2016 02:00AM
I designed and built spare extruder for my e waste 3d printer.
The goal was to make extruder using available e waste parts.
VIDEO: https://youtu.be/3uxwgVQLpPY
Edited 1 time(s). Last edit at 08/01/2016 02:37AM by kestux75.
My 3D printer videos [www.youtube.com]
My E-Waste CNC videos [www.youtube.com]
Re: E-Waste Extruder
August 11, 2016 10:11AM
Looks great I think I might have the same motor from a printer I disassembled.
What is the diameter of your motor?
Can you release the model of that extruder?
August 16, 2016 04:08AM
Thanks,
The diameter of the motor is 35mm.
From a printer you also will need the gear that comes next to worm gear and rubber roller to mount on this gear.
I will try to attach stl files later.
I can send Solidwors project by email also.
August 18, 2016 04:16AM
Attached STL files
Assembly instructions - [youtu.be]
open | download - Body.STL (217.8 KB)
open | download - Bearing bracket.STL (63.4 KB)
open | download - Spring holder.STL (42.2 KB)
open | download - Spring end.STL (40.3 KB)
October 20, 2016 09:40AM
How much does it cost?
