Vertical filament extruder
Posted by [email protected]
October 04, 2016 07:41AM
[www.thingiverse.com]
Changing the Lyman/Mullier into a faster and easier to use extruder, also trying to make it cheaper then the original Lyman. Tested it at speeds till 3000mm/min or 10 feet/min for 3.00mm filament, currently around +/-0.2mm but believe that can be improved.
Re: Vertical filament extruder
October 12, 2016 02:47AM
this looks great!
I don't see the stl files except one (leg).
Do you plan to publish all the files (also with firmware and schematics)?
October 13, 2016 04:55AM
olisoft
Not everything is released yet as it is still a project in progress and certain parts are not correct or finished yet. For example the enclosure for the electronics is not finished and the firmware has a bug in the temperature auto-tune routine.
