Re: Tripteron Implementation November 08, 2016 01:35AM |
Re: Tripteron Implementation November 08, 2016 08:05AM |
Re: Tripteron Implementation November 08, 2016 08:50AM |
Re: Tripteron Implementation November 08, 2016 11:03AM |
mavu
Very intersting!
You could theoretically even go with the stepper gear wheel driving directly on a rack, thus removing belts alltogether.
And if I understand this correctly, on every axis the force on the arm is only along that axis, so if you wanted you could make the arms slimmer and wider. because it only experiences strain parallel to the wide surface?
Re: Tripteron Implementation November 08, 2016 03:47PM |
Re: Tripteron Implementation November 09, 2016 06:38AM |
Re: Tripteron Implementation November 09, 2016 10:48AM |
Re: Tripteron Implementation November 09, 2016 01:31PM |
Rest of the video is a good indication of how smooth the motion is with these settings.
Re: Tripteron Implementation November 10, 2016 03:46PM |
Re: Tripteron Implementation November 11, 2016 01:19AM |
Re: Tripteron Implementation November 11, 2016 11:28AM |
Re: Tripteron Implementation November 13, 2016 03:52PM |
Re: Tripteron Implementation November 14, 2016 02:11PM |
Re: Tripteron Implementation November 14, 2016 02:23PM |
o_lampe
Now that you've "discovered" the thrust bearing advantage, do you still need the extra beefy 608 bearings? Initially I thought, needle bearings would be useful. What do you think?
There is a saying in german: There is never enough time to do things right, but then there is always time to do it again....
Re: Tripteron Implementation November 15, 2016 02:33AM |
Re: Tripteron Implementation November 15, 2016 09:55PM |
Re: Tripteron Implementation November 16, 2016 02:38AM |
Re: Tripteron Implementation November 16, 2016 11:21AM |
o_lampe
Yeah, 2020 extrusion will make it for sure!
Don't want to be nagging, but I still think carbon rods are even better and also widely available.
Re: Tripteron Implementation November 18, 2016 10:01AM |
Re: Tripteron Implementation November 18, 2016 01:34PM |
Re: Tripteron Implementation November 18, 2016 06:02PM |
Re: Tripteron Implementation November 18, 2016 08:10PM |
Re: Tripteron Implementation November 19, 2016 08:30AM |
Re: Tripteron Implementation November 19, 2016 06:03PM |
o_lampe
I love the looks of it, but maybe the center platform needs an redesign? It seems to be pretty tight to mount a hotend.
Re: Tripteron Implementation November 20, 2016 03:30PM |
It's equidistant from each axis using a particular method. Might change to a different one, we'll see.|
Re: Tripteron Implementation November 21, 2016 08:06PM |
Re: Tripteron Implementation November 23, 2016 10:25PM |
Re: Tripteron Implementation November 24, 2016 03:45AM |
Re: Tripteron Implementation November 24, 2016 01:28PM |
o_lampe
Awesome!
That looks better than the first layer of my delta ATM
BTW: I linked your Tripteron thread to this vacuum bed one, because they would be a perfect match. Maybe I can lure you into building a conveyor belt bed
Re: Tripteron Implementation November 24, 2016 02:29PM |
