Re: Tripteron Implementation November 25, 2016 10:18AM |
Re: Tripteron Implementation November 25, 2016 10:27AM |
o_lampe
With a little longer extrusion, you could win a bit print room,too.
The MGN12 rails are sold in fixed length, but 2020 extrusion sells tailored to your needs. See blue circles in the attached pic.
Re: Tripteron Implementation November 25, 2016 01:00PM |
Re: Tripteron Implementation November 26, 2016 01:21AM |
Re: Tripteron Implementation November 26, 2016 03:27AM |
Re: Tripteron Implementation November 26, 2016 07:16AM |
Re: Tripteron Implementation November 26, 2016 02:22PM |
o_lampe
Good job, Sir!
I've seen worse test cubes.
In the side view I see some regular wobble every 5-6 layers. Makes me wonder if the z-stepper would need a gearbox or just a lead screw drive?
..now back to watching this video again
Re: Tripteron Implementation November 27, 2016 11:22PM |
Re: Tripteron Implementation November 28, 2016 10:29AM |
Re: Tripteron Implementation November 28, 2016 11:03AM |
kayrangandhi
From the experience with bearing joints, do you think making a planar joint with a bearing joint+ a linear rail would be a good idea?
Re: Tripteron Implementation November 28, 2016 11:40AM |
Re: Tripteron Implementation November 28, 2016 12:14PM |
Re: Tripteron Implementation November 28, 2016 12:36PM |
Re: Tripteron Implementation November 28, 2016 12:49PM |
the_digital_dentist
I don't know if the sag in the arms would be linear and correctable by just tilting the print bed. It seems like the motion might define a pretty complex, unflat surface.
Re: Tripteron Implementation November 28, 2016 01:33PM |
Apsu
kayrangandhi
I'm not 100% sure what you mean by planar joint or bearing joint + linear rail. I've got linear rails already, to which the shoulder bearing joints will attach. Do you mean a compliant laminar joint by "planar joint"?
Re: Tripteron Implementation November 28, 2016 04:05PM |
kayrangandhi
Apsu
kayrangandhi
Something like this
Re: Tripteron Implementation November 29, 2016 09:19PM |
Re: Tripteron Implementation November 29, 2016 10:23PM |
Apsu
kayrangandhi
Apsu
kayrangandhi
Something like this
Ah, gotcha. I misread you at first. I'm not sure why you'd want that necessarily, certainly not for this application. You'd need a motor on the shoulder joint to drive the second rail in relation to the carriage, and that would significantly weight the whole assembly. Not to mention the rails are hardened and made of steel, so they're not remotely lightweight
Re: Tripteron Implementation November 30, 2016 12:52AM |
kayrangandhi
What i meant with that draft assembly was to try another way to assemble one of the arms of the tripteron, using the same effector, but looking for more arm rigidity and less joint play/backlash. Of course the full design would have one assembly like that per tower.
Correct me if I'm wrong, but I understand each arm defines a tilted circle that slides along the vertical tower and the effector location is defined by the intersection of the 3 tilted circles right? So having a linear rail free to slide and whose carriage turns over a bearing could be another way to define a circular workspace the same as two segments with a bearing. One advantage would be having screw holes for fixing the bearing.
Anyway, keep up this very interesting work. Besides the advantages you cited, the weight applied on the arms can help with backlash acting as a pre-load. And the IK is quite elegant and 8-bit friendly, do you have hints on how to use it on Marlin?
I'm currently designing/building a Kossel with magnetic joints and I'm seriously considering designing compatible MGN12 carriages and effector with some 608s I have laying around.
Re: Tripteron Implementation November 30, 2016 01:20AM |
Re: Tripteron Implementation November 30, 2016 04:50AM |
Re: Tripteron Implementation November 30, 2016 07:58AM |
Re: Tripteron Implementation November 30, 2016 10:28AM |
o_lampe
I don't want to rain on your parade, but I don't see huge advantages against a common delta or the cartesian tripteron?
OK, you win headroom against a delta, but the elbows sticking out everywhere weights more against it.
Have you done the same simulation ( hollow 2020 arms ) with the last tripteron? Is there a significant difference?
I'd spend more time in improving the cartesian tripteron.
Especially one sentence of the tripteron paper regarding this delta worries me:
They said it is over constrained and they consider using ball joints on the effector.
To me that sounds like you have to build it with no tolerance in alignment to make it work without binding..
Sorry if I sound a bit negative, I just had a 24h print fail in the middle of a print...
Re: Tripteron Implementation November 30, 2016 12:58PM |
Re: Tripteron Implementation November 30, 2016 04:41PM |
Re: Tripteron Implementation November 30, 2016 05:17PM |
Re: Tripteron Implementation November 30, 2016 05:29PM |
kayrangandhi
I don't see why you couldn't do that with the Delta version
Re: Tripteron Implementation November 30, 2016 05:40PM |
Lykle
I love how in the square version, you can print on any surface. You can place it on any flat surface and print something.
With good calibration, you could print an object straight onto the roof of a car, for instance. Mount it with sucker feet, calibrate and print a new air scoop. Magic!
I need to start experimenting with one. Man you do good work!
Lykle
Re: Tripteron Implementation November 30, 2016 05:49PM |
Re: Tripteron Implementation December 01, 2016 12:13AM |
