Re: Tripteron Implementation December 02, 2016 12:11AM |
Re: Tripteron Implementation December 03, 2016 02:17PM |
Re: Tripteron Implementation December 03, 2016 07:31PM |
Re: Tripteron Implementation December 04, 2016 02:47AM |
Re: Tripteron Implementation December 05, 2016 04:23PM |
Re: Tripteron Implementation December 06, 2016 01:05PM |
Re: Tripteron Implementation December 06, 2016 01:37PM |
nicholas.seward
Awesome work!
Side thought: All of those joints have pretty low angular velocity. A pin joint could perform very well here.
Re: Tripteron Implementation December 06, 2016 02:03PM |
Re: Tripteron Implementation December 06, 2016 02:45PM |
Re: Tripteron Implementation December 06, 2016 04:02PM |
zelogik
First, fantastic work! But why ? :p
No seriously, design new concept is really interesting but with this concept what is the advantage again delta/corexy/simple cartesian ?
Seem like there is many effort/torque on that joints that can be problematic with precision. no?
I really curious about repeatability and precision.
To me (and just to me), the only pro for a machine like this, is that it's just beauty to see kinematic moving in a non cartesian movement
Of course it's not critics! just curious about pro/con
Re: Tripteron Implementation December 09, 2016 03:16PM |
Re: Tripteron Implementation December 10, 2016 10:20AM |
Re: Tripteron Implementation December 10, 2016 01:17PM |
Re: Tripteron Implementation December 10, 2016 03:48PM |
leprud
Hello!
I'm also trying to buid tripteron.
At first i wanted it to be without any linear slides, only trapezoidal screws, but failed to mount arm on nuts, that it won't move, so i had a "leaning" sideways arm, as nuts "tickle" on screw. Of course used two nuts, different rubbers, screws, elongations, etc. Nothing helped..
[www.youtube.com]
So i ordered linear slides and this is what i've done today. No plastic, only 2040 extrusion (left from other projects), some 20*20 aluminum tube, screws and so on.
[www.youtube.com]
Re: Tripteron Implementation December 10, 2016 07:11PM |
leprud
Hello!
[www.youtube.com]
[www.youtube.com]
Re: Tripteron Implementation December 11, 2016 03:47AM |
Apsu
Very cool!! I worry a little about your joint stiffness, but it looks you're using self-aligning bearings in those effector housings, and bushings or thrust washers in the other joints. That could definitely work if the bolt holes are accurate enough and bolts clamped down. As you discovered, designing and building your own joints in a way that they rotate smoothly but retain their orientation under load is actually pretty hard!
Definitely keep us posted, happy to answer any questions about the orthogonal design if you have any.
Re: Tripteron Implementation December 11, 2016 03:54AM |
Of course i saw LISA (and other your cool ideas) and her problems..Quote
nicholas.seward
I had a similar problem with LISA Simpson. I ended up making a zero clearance extension to one side. Video linked below.
That said...screws will wobble and arm angle changes will effect your position on the screw making the kinematics problematic. I considered using screws for a Tripteron a few times but the recouping of the kinematics always turned me off along with my experiences with LISA. (LISA is fun but ultimately impractical.)
If you want to make a Tripteron without linear motion, there a few options but they all require more linkages between ground and the effector making it even harder to make rigid enough. That said... I am always up for discussing crazy ideas. I find they lead to interesting solutions.
Re: Tripteron Implementation December 11, 2016 01:20PM |
Re: Tripteron Implementation December 11, 2016 01:27PM |
leprud
So, quickly put the belts on and gave it a test run.
Well, could be better..
[www.youtube.com]
Re: Tripteron Implementation December 11, 2016 01:44PM |
leprud
[www.youtube.com]
Re: Tripteron Implementation December 11, 2016 01:47PM |
kayrangandhi
leprud
[www.youtube.com]
Isn't it lacking an elbow joint on z arm? Looks like without that your workspace is limited to a cilinder around z tower.
Good job though, I can't wait for my linear rail to arrive to try a drop in adaptation for my Kossel.
Re: Tripteron Implementation December 11, 2016 01:49PM |
Apsu
kayrangandhi
leprud
[www.youtube.com]
I see elbows on all three arms. Take a closer look.
Re: Tripteron Implementation December 11, 2016 02:03PM |
Oh yes! It shakes like it always wanted to make a "harlem shake"Quote
Apsu
Not a bad start! I'm sure you see what I see, which is the Z tower wobbling, just like it did in my build. If you brace that up it should improve the behavior quite a bit. Looking decent!
Re: Tripteron Implementation December 11, 2016 02:18PM |
leprud
Apsu
I hope more brackets will help me, as now only one bracket is supporting Z tower.
Also, need to rethink of joints, maybe loosening it will not give so much backlash as i thought.. For now, Z motor can't even move it down on full current
Re: Tripteron Implementation December 11, 2016 02:22PM |
Re: Tripteron Implementation December 13, 2016 01:08AM |
Re: Tripteron Implementation December 14, 2016 04:42AM |
Re: Tripteron Implementation December 14, 2016 11:35AM |
o_lampe
I just found another motivation for me than just curiosity to build an ortho-tripteron.
I think it's a good platform for a huge laser engraver. The focus of the laser allows a small amount of deflection in z-axis and the "bed" could be anything I want to engrave on.
DC42's new firmware allows to scan a height map of the surface, which would help ironing out any imperfections of it.
Re: Tripteron Implementation December 15, 2016 03:40PM |
Re: Tripteron Implementation December 16, 2016 10:18AM |
