Relai SSR & silicone 200v 300w
November 02, 2017 11:16PM
Hello,
I have a heating silicone 200V 300W that must be driven by an SSR.
By consulting the nomenclature of SSR appellations,
I conclude that we need a model SSR - xAmp A D
then according to the following connection scheme
I see that it is a DA model.
which model SSR AD or DA is most appropriate?
Is the connection scheme reliable?
thank you
Re: Relai SSR & silicone 200v 300w
November 25, 2017 12:48PM
Obviously - DA
D - DC on input (to RAMPS)
A - AC on output (to mains)
December 10, 2017 11:58PM
Hello,
I made a schema for connecting the SSR relay. I have a doubt about the connection between IEC switch C14 and SSR & hearter.
Should I connect the bed and ssr on the same terminal of the switch?
j'ai fais un schèma pour la connexion du relais SSR. J'ai un doute sur le branchement entre le switch IEC C14 et SSR & hearter.
Faut-il connecter le bed et le ssr sur la même borne du switch?
Edited 1 time(s). Last edit at 12/11/2017 02:17AM by taratata.
open | download - - Schema.jpg (509.5 KB)
