Cast Urethane Wheelchair Push Tabs December 21, 2018 08:18PM |
Re: Cast Urethane Wheelchair Push Tabs December 23, 2018 08:07AM |
Re: Cast Urethane Wheelchair Push Tabs December 23, 2018 02:36PM |
Re: Cast Urethane Wheelchair Push Tabs March 28, 2019 01:40PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Cast Urethane Wheelchair Push Tabs March 30, 2019 07:33PM |
Ohmarinus
I can imagine making a 3-stage mold where you first cast some softer PU, then remove a mold piece to cast the rest of the harder PU. These two should be able to bond together so you have the construction with hard solid PU and a softer part where your more fragile skin/hands have to touch it.
Re: Cast Urethane Wheelchair Push Tabs April 03, 2019 10:49AM |
Garry Bartsch
Ohmarinus
I like this idea very much. Maybe in the future I will try that. Can you recommend a soft PU? We used Smooth-on material for this.
Re: Cast Urethane Wheelchair Push Tabs April 06, 2019 05:08PM |
Ohmarinus
Unless you like to experiment, which I think you do
